EQ5000 battery with H3Smart inverter - BMS lost issue
Posted: Thu Sep 24, 2026 10:13 am
by paynie
i am owning a new system, equipped with inverter and battery. While the inverter works in general, feeding in solar power to the grid, my battery fails with bms lost message. In addition the inverter shows a battery voltage of 0v and battery switches itself off after a while, as communication seems to be faulty. the bms cable, a rj45 cable is ok, it is a rather short connection and using a rj45 cable tester, all contacts are fine. I am wondering if the battery voltage connection itself is faulty?
How do i properly disconnect it for a check(after powering down the whole system)
Any ideas? Currently my dealer, who also installed the system, is not reacting at all
Thank you
Kind regards,
Paynie
Re: EQ5000 battery with H3Smart inverter - BMS lost issue
Posted: Thu Sep 24, 2026 3:56 pm
It sounds like a flaky comms cable between the inverter and BMS (i've seen quite a few of these); If the inverter and BMS cannot reliably communicate, the BMS opens it's contactor and disconnects the battery (hence you seeing 0V).
Obviously make sure that you have latest firmware on the inverter and batteries, but i'd start by powering off the batteries, open the DC isolator switch - then replace the inverter to BMS cable with a new one.
Posted: Thu Sep 24, 2026 8:20 pm
by paynie
Hi Dave,
thanks a lot for your fast answer.
I exchanged the cable and performed a complete system restart, but with no success.
After restart i realized the blink codes on the EQ5000 battery.
For a couple of minutes the BMS LED blinked green 0.5s on/off, which is according to manual bootup.
During boot up phase the SOC LEDs signal a SoC between 25% and 50%.
Afterwards it changed to BMS blinking red with the four SOC leds being solid green.
According to manual this means PCS communication failed.
At the same time the inverter did already start to display BMS lost with a blinking red LED.
From the cloud app i can see the used versions:
FW Version Master 1.44
FW Version Slave 1.0
FW Version Arm 1.26
It also throws error 14 - communication fault between device and battery in the dashboard.
Is there anything else, what i can check?
The battery did not yet work at any time.
Kind regards,
Paynie
Posted: Fri Sep 25, 2026 1:25 pm
Your Master/Manager(ARM) are older versions and could do with being updated, latest is Master 1.49, Manager(ARM) 1.31 - but I am doubtful that is causing this problem although it is best to rule that out by updating.
It is certainly consistent that there is a comms fault between Inverter and battery and the lights on the battery also concur with what the inverter is reporting.
As this is a new install, I would run through the obvious things such as the lowest slave battery has the 'waterproof' cover fitted - this isn't just a waterproof cover as it provides the return link to complete the circuit between master and lowest slave battery.
Also the battery ground connector should have been installed from the master batteries earth point and the inverters earth point (usually on the lower right hand side depending on inverter).
If all of those checks are good and you are on latest firmware, I would recommend raising a ticket with Fox service so they can verify the install and just in case there is a specific use case for the H3 smart with different battery firmware.
Posted: Mon Sep 28, 2026 9:38 am
by paynie
Hi Dave,
thanks again for your detailed response.
All fw updates were performed now, no change.
The battery cover on the lowest battery is installed.
One question here.
The BMS cable pinout shows an alarm signal and two CAN channels.
Are there really two CAN channels or is it just the same channel with return? - as you speak about return link
As a CAN bus is terminated on both ends with 120 ohms, i should be able to measure the termination.
Kind regards,
Paynie
