Data logger not showing
Posted: Sun Sep 20, 2026 5:52 pm
by Entwood
Hi, another daft question from the newbie... :)
Numerous posts I've read mention a "data logger" but one doesn't appear in my device list.... I worked out that I must have one or no data would appear in the app, so playing around ... if I go to "add device" there is one there, but says it is "unbindable", tap further says "incorrect serial number".....
Now as this is, apparently, working, should I be bothered? or should I continue and try and "fix" it by, somehow finding the "correct" serial number ? If the latter any ideas where I would find it, as I don't even know what one looks like !!!
Next stop is google to try and find a picture, but any pointers gratefully accepted !!
Regards, Nige
Re: Data logger not showing
Posted: Sun Sep 20, 2026 5:57 pm
by MaterialBarracuda48
You can take a picture of under the inverter and post it up, it will look like a lollipop usually.
I wouldn't be too concerned if you are getting data out of it 8-)
Posted: Sun Sep 20, 2026 7:39 pm
by Entwood
Thanks for that. Away from home for a few days so will look around when we return.
A thought occurs however, Fox H1 (G2) inverter is supposed to have built in wifi according to Internet spec sheet, would the serial number required be the same as the inverter serial number, or is that too simple ......
Regards, Nige
Posted: Sun Sep 20, 2026 8:22 pm
If built in, then it might not show as a separate data logger device then.
Perhaps some member with same hardware can confirm?
Posted: Sun Oct 04, 2026 7:18 pm
by Entwood
Hi all, just to update on this.... spoke to installers who confirm that the data logger is "built in", it was initially showing as a separate item because that's the way the app presented it. Since the app upgrade it is now "correctly" showing as part of the inverter. I have go Device/inverter then tap on the serial number below the inverter symbol (white box) when a window "About Inverter" opens.... this shows several things including the latest software versions, including the data logger.
So it is there, just in a different place 🙂
Posted: Sun Oct 04, 2026 7:46 pm
Thanks for updating your post.
