All in one or separated battery / inverter
I've put an order for a EVO 8kw inverter / 10kwh battery. and I have some second thoughts.
Does anyone how repairable are these units vs separated battery / inverter ?! :?: :!: :?:
Don't want to be put in a situation (even outside of warranty) where I need to replace the entire thing for a faulty inverter, or a battery module) -- makes no financial sense to get the EVO if this is the case.
Re: All in one or separated battery / inverter
I’ve not (yet) known one to go faulty but the components within it are modular, using the same batteries and similar inverters running a modified firmware for the all in one application - quite a few EVO owners on here so hopefully they can add some finer detail on ownership.
