Automate Everything?
Posted: Thu Sep 17, 2026 10:01 am
I have a Fox Evo 10-5h with 7 panels. I'm getting to grips with how to best utilise the system to generate income. This is my current setup:
Octopus Go import: 9.5p night rate
Octopus Outgoing: 12p export rate
Octopus Power Down: 82 octo-points (10p) per kwh export + free 1 hour of electric on the weekend
Axle VPP: £1 per kwh export
Essentially I get 22p export when there is a power down event (12p export + 10p octo-points).
Or £1.12 per Axle grid event.
And I charge overnight at 9.5p every night
The problem with making the most of the setup is that I have to manually schedule the power down event and stop the nightly charge the day before the free electric hour. The Axle event is automatic (most of the time).
I'm wondering if Home Assistant or any other software can automate this? I.e. Friday there is a power down event at 7pm so it exports to set limits, and then doesn't charge overnight to make best use of the free hour on Saturday?
I hope that makes sense.
