Grid import instead of battery discharge through the night?
Posted: Wed Sep 09, 2026 2:39 pm
by Rob
Hello Forum. Hoping someone can help. In the last 6 weeks, from 9pm to 6am, my house use of power is pulling from the grid and not from my very full battery. I have attached a pic to show what I mean. I am in silent mode through the night but the times are not the same as when the draw from the grid happens. We don’t export to the grid at all so don’t think that can be an issue. Does anyone have any suggestions as to why this may be happening as would like to use my battery power through the night?
Re: Grid import instead of battery discharge through the night?
Posted: Wed Sep 09, 2026 6:30 pm
Can you post any schedules that you have set, along with your default minsoc settings - also worth double checking that the time shown on your inverter screen is correct
Posted: Wed Sep 09, 2026 8:41 pm
by Rob
Hi Dave
I have
Heat Source - set for all day
DHW - set fro 6am to 7 am and 4pm to 5pm
Circuit 1 which is set from 6am to 10 pm
Silent Mode - set from 10pm to 4am
I have attached the Munson setting
Rob
Posted: Wed Sep 09, 2026 9:01 pm
by MaterialBarracuda48
Your scheduler is not set to charge during the night, given that you don't charge at night currently, what happens if you set the system to 'Basic work mode: Self-use'
As it is almost 9pm when the battery goes into standby, now would be a good time to swap work modes and check. If you have the 5 second refresh of live data on your FoxCloud2.0 App, then you will see quickly if the system is discharging from the battery or not.
Posted: Wed Sep 09, 2026 9:29 pm
by Rob
Hi there. Thank you. I think I am in self-use but attached a pic below. Also another chart showing how 30 mins ago power for the house is coming from the grid and not the battery
Posted: Wed Sep 09, 2026 9:45 pm
Rob wrote: ↑Wed Sep 09, 2026 9:29 pm
It looks like it has taken the change to the basic 'self-use' work mode.
On the power graph picture, it is as you are saying... taking power from the grid.
However, did you swap work mode at 21:23, or a little earlier?
On your home screen, where you see the house, do you have the 5 second refresh to the data?
You might also have to do a full power down and reset if the battery is not responding correctly.
Posted: Wed Sep 09, 2026 10:29 pm
by Rob
Thank you. I missed swapping mode earlier so will give that a go and see what happens
Posted: Thu Sep 10, 2026 10:53 am
by Rob
Hi there. Yes I have the refresh - pic attached and I am in self use. Any other ideas as to why I am taking power from the grid and not my battery through the night?
I have attached a chart of when we were taking power through the night from the battery. The change to taking power from the grid instead of the battery seems to have happened on the 7th June and can’t think of anything we changed at this time do really odd.
Posted: Thu Sep 10, 2026 11:35 am
Looking at your latest image, there is only 0.3kWh of grid power used in a 24hr period. You are always going to pull some power from the grid, there is a setting you can adjust for meter compensation.
See this post here, and set perhaps a bias of 13W of Export? ( (0.3kWh x 1000W) / 24hrs) = 12.5W average grid pull ) viewtopic.php?p=17996#p17996
If you have some other days you can post graphs for, if you are unsure, they can be looked over. Do not worry too much about the grid import at night, it is the overall picture (24hrs) that you need to look at.
Posted: Thu Sep 10, 2026 12:24 pm
by Rob
Hi there.Thank you for taking the time to look at this. Absolutely happy to take 0.3 kWh from the grid over 24 hrs but since the 7th June, this is what has changed so for example yesterday , we pulled 2 kWh from the grid over 24 hrs which I thought was a bit excessive when we had lots of battery power. What do you think - see pic.
Posted: Thu Sep 10, 2026 1:25 pm
Have you done a system restart, so a full shutdown of Inverter and Battery?
Can you check on your firmware versions, are they woefully out of date?
Posted: Thu Sep 10, 2026 2:17 pm
by Rob
Hi there
Manager needed updating but can’t be hugely out of date as only installed last September. I am so nervous to do a system restart as not done before and worried I will mess settings and anything else up.
Posted: Thu Sep 10, 2026 4:43 pm
Will has you covered, and it won't break your system!
Just take a few minutes to identify the different switches, DC & AC isolators, then your battery power switch.
Posted: Thu Sep 10, 2026 4:56 pm
by Rob
Thank you. Do you think pulling 2.0kwh from the grid through the night and nothing from the battery is a bit excessive when it was doing 0.3kwh a couple of months ago?
Posted: Thu Sep 10, 2026 6:26 pm
Rob wrote: ↑Thu Sep 10, 2026 4:56 pmThank you. Do you think pulling 2.0kwh from the grid through the night and nothing from the battery is a bit excessive when it was doing 0.3kwh a couple of months ago?
Yes, it should be working as intended... in 'Self-use' work mode, it should be using that during the night, and not stopping at around 8pm/9pm (depending on when it plays up)
I would get that reboot done to cross that off the list, and check tonight/this evening after the battery usually goes to sleep, if it is providing power.
Posted: Thu Sep 10, 2026 7:21 pm
by Rob
Thank you
Posted: Fri Sep 18, 2026 2:37 pm
by Rob
Hi there. We plucked up the courage to try a restart and found a hiccup after watching the video. I have attached photos.
1. We seem to have 2 DC isolators( or at least 1 labelled isolator and the other mentions solar wiring) plus we have the switch under the inverter mentioned in the video. Do we turn all 3 off or 1 or 2 of these?
2. Then, we seem to have 2 Isolators - 1 outside on our wall where the inverter
is and 1 inside near our fuse box. Do we turn both off or 1 and if 1, which 1?
3. Then we don’t seem to have a circuit breaker on the battery box I have attached photos of each side to show.
4. Finally, the video says to isolate the D.C. first. On the inverter label, it says isolate the AC first - I have circled the picture.
Thank you in advance and hoping you can help these novices
Posted: Fri Sep 18, 2026 3:27 pm
From my own handover sheet
1. Turn OFF the PV supply at the consumer unit.
2. Turn OFF the AC isolator at the consumer unit.
3. Switch the AC Isolator at the inverter to OFF.
4. Switch the DC Isolators at the Inverter to OFF.
The consumer units in my case are in garage with my kit, so the two metal tins on the left side, underneath the cupboard.
The 3x DC Isolators are as follows, the inverter one will be sort of redundant (no need to turn off)
The other two bigger switches should be for PV and your battery.
If you are unsure, turn them all off. Just note on your battery, if you rotate the breaker on the left side... once you turn it back on, you have to hold down the silver button on the right afterwards to power it up.
If you are still unsure on some point, let me know.
Posted: Fri Sep 18, 2026 3:53 pm
by Rob
Thank you and the circuit breaker - where is this?
Posted: Fri Sep 18, 2026 3:55 pm
by Rob
Posted: Fri Sep 18, 2026 3:58 pm
Hopefully in your fuse box (aka consumer unit)
In my example, it's a fuse inside the metal tins
Posted: Mon Sep 21, 2026 9:18 am
by Rob
Hi there. We did the restart but sadly didn’t change the issue. I have attached photos. We did the restart at about 3pm yesterday hoping to see a change through the night. As you can see, pic 1, at 8pm power started coming from the grid not the battery ( the battery was 74%charge at this point). This carried on all through the night and into today where at 6am this morning , when the battery was still at 74%, the battery discharge began. The spike at 6am is the hot water.
Any ideas welcome as it is a mystery to me. Thank you in advance. Rob
Posted: Mon Sep 21, 2026 9:19 am
by Rob
Seems my pics have attached wrong way around
Posted: Mon Sep 21, 2026 10:08 am
A slightly crazy thought, but can you post the firmware versions for your battery - there were a bunch of issues on older 'warm' EP batteries where the battery started taking power from the grid when the battery heater was turned on. Also worth clearing any battery heater schedules you have set.
Posted: Mon Sep 21, 2026 10:36 am
by Rob
Hi there. I have attached pics of the 2 things. Do they look OK?
I do have an economy 7 tariff through the night but the times of this don’t coincide(12 to 7) and also when the problem started did not coincide with when I changed to the tarrif) so crossed that off the list.
