EV Charger first then battery during daytime with PV linkage
Posted: Sat Aug 29, 2026 3:59 am
Hi FoxESS Team,
I am running a 3-phase setup featuring an H3 Smart 15kW inverter, CQ7 batteries, an 11kW 3-phase EV charger (L11P), and solar panels.
With "PV Linkage" and "Self-Use" modes active, the current priority is Home Load → Battery Charging → EV Charger, with PV Linkage already handling dynamic current control for green solar power. I would like to propose adding a new toggle in the app to switch between the existing logic and an optimized EV-first priority mode.
Suggested Priority Logic (New App Option)
Tier 1: Home Load (always prioritized first).
Tier 2: EV Charger, powered by solar generation and battery discharge simultaneously to speed up charging times.
Tier 3: Batteries (absorb any remaining surplus solar power after home and EV demands are met).
Dynamic Integration: Retain the current PV Linkage intelligence to dynamically throttle or stop EV charging based on the 15kW inverter capacity, but apply it to this new combined solar-plus-battery workflow.
