KH10 (2026 hardware) - RS485 connection location
Posted: Wed Jul 22, 2026 3:05 pm
by intelligentcookie
Hi everyone,
I have a FoxESS KH10 hybrid inverter installed in July 2026 with a KH-WL Wi-Fi logger.
I'm trying to connect a Waveshare RS485-to-Ethernet (PoE) gateway for Home Assistant using the foxess_modbus integration.
The published KH10 installation manual shows a removable Meter/CT/RS485 connector with RS485 A/B terminals, but my inverter hardware is different. That connector is not present, the CT wiring goes directly to the PCB using JST-style connectors, and I cannot locate any labelled RS485, COM, A/B, Meter or Data terminals.
Has anyone with a 2025/2026 KH10 successfully connected to the inverter using RS485?
Specifically:
Where are the physical RS485 A/B terminals?
Has FoxESS changed the communications hardware on newer KH10 units?
Is there an updated service manual or wiring diagram showing the current hardware?
Any photos or guidance would be greatly appreciated.
Re: KH10 (2026 hardware) - RS485 connection location
Posted: Wed Jul 22, 2026 5:24 pm
by Will
With a WL version you don't need to wire anything as the modbus server is built into the inverter. You would simply select Direct LAN when setting up the plugin in Home assistant targetting the inverters IP address.
You might need to submit a bug report to the git project to get the WL Version supported if its not already supported.
Posted: Wed Jul 22, 2026 6:04 pm
Hi Will thank you for that, that's really helpful.
My KH10 was installed in July 2026 and has the KH-WL logger.
I originally planned to use a Waveshare RS485-to-Ethernet (PoE) gateway because I couldn't find the RS485 A/B terminals shown in the published KH10 installation manual. After inspecting the hardware, it appears the newer inverter revision no longer has the same accessible RS485 connection.
My inverter is connected to my home network via Ethernet (not Wi-Fi) using the KH-WL logger, and I can access the logger's local web interface without any problems. The inverter has a fixed IP address on my LAN and is fully reachable over the network.
However, when I configure foxess_modbus using Direct LAN and target the inverter's IP address, it cannot establish a Modbus connection. I also scanned the device from another machine on the same LAN and only HTTPS (port 443) appears to be open—Modbus TCP on port 502 does not appear to be listening.
Could you clarify:
Is Modbus TCP on port 502 expected to be available on current KH-WL firmware when connected via Ethernet?
Does the KH-WL expose Modbus through the Ethernet interface, or only under certain firmware versions/configurations?
Has the communication method changed on the newer 2026 hardware revisions?
If the hardware supports Direct LAN, is this a limitation of the current foxess_modbus integration rather than the inverter itself?
I'm happy to provide my KH-WL firmware versions and help test if that would be useful.
Posted: Tue Jul 28, 2026 12:37 pm
by asleep
Did you make any progress on this? I'm getting a KH10 installed next month and I assume it will have the KH-WL logger as well (although need to confirm this with my installer). I was planning to get a modbus adapter to wire in but if this isn't feasible or necessary then I need to rethink.
Posted: Tue Jul 28, 2026 1:23 pm
Hi Asleep
Yes, I've made quite a bit of progress since starting this thread.
My KH10 (installed July 2026) also has the KH-WL logger. I initially went down the same route as you and bought a Waveshare RS485-to-Ethernet (PoE) gateway because Direct LAN wasn't working for me.
Following Will's advice, I spent a long time trying to get Direct LAN working. The inverter was connected to my home network via Ethernet with a fixed IP address, and I could access the KH-WL local web interface without any problems. However, foxess_modbus could never establish a Direct LAN connection. Port scans only showed HTTPS (443) and there was nothing listening on port 502, so Modbus TCP was never available on my unit.
That said, Fox Cloud works perfectly, so if you don't need local control or local polling, you'll still be able to monitor your system via the FoxESS app and the Home Assistant Fox Cloud integration. My goal, however, was a completely local connection with no cloud dependency.
In the end I decided to use a physical RS485 connection instead.
The good news is that this does work. I'm now connected locally to Home Assistant using foxess_modbus over RS485 and have full access to the inverter data and controls (PV, battery, grid import/export, SoC, charging/discharging, inverter settings, etc.). It's fast, reliable and doesn't depend on the cloud.
For anyone planning to do the same:
- The RS485 connection uses the same communication connector as the CT clamp.
- On my inverter, the CT clamp is connected to pins 7 and 8, while the RS485 pair is connected to pins 3 and 4.
- At the Ethernet gateway end, the RS485 pair connects to the A (D+) and B (D-) terminals on the Waveshare RS485-to-Ethernet gateway. Mine is configured for Modbus TCP to RTU, 9600 baud, 8 data bits, no parity, 1 stop bit (9600 8N1).
So my conclusions at the moment are:
- Direct LAN may work on some KH-WL units or firmware versions, but it did not on mine despite extensive testing.
- Physical RS485 definitely works on the current KH10 hardware once connected correctly.
- Fox Cloud remains available regardless, so you aren't left without monitoring while investigating local Modbus.
- If you're having your system installed soon, I'd ask your installer to leave access to the communications connector, or even better, install an RS485 cable while they're on site. It's only a few extra minutes during installation but could save a lot of work later if Direct LAN doesn't work on your unit.
I'm still interested in hearing from FoxESS whether newer KH-WL firmware is supposed to expose Modbus TCP over Ethernet, or whether there are differences between hardware or firmware revisions. If anyone from FoxESS can clarify that, it would be really useful.
Hopefully that helps with your planning.
Posted: Tue Jul 28, 2026 2:10 pm
by asleep
Thank you, super helpful to hear how you got it working. Looks like it makes sense to go ahead with the RS485 physical connection and gateway. I'll pick this up and see if I can get the installer to connect to the inverter when they do the install.
Posted: Sun Sep 06, 2026 7:07 am
by Newbs
I’m in the same boat, I’ve just had a KH10 installed. How do you know if it’s the WL version? Nothing on the box denoted this model but I do have a black WiFi dongle with LAN connection at the bottom of the dongle in the bottom of the unit and it’s connected to WiFi and I can use the app.
I cannot seem to connect to the IP address through my browser. Is a local web interface something the installer can enable? If I try port 443 I get connection unexpectedly closed.
I was going to get either ew11 or ew41 for rs485 comms but might hold off for a week or 2.
How often are firmware updates pushed out? My data logger firmware updated but the inverter hasn’t, however I am waiting for the battery to turn up in 5 days time.
Posted: Sun Sep 06, 2026 8:40 am
Hi Newbs,
From what you describe, it sounds very similar to my setup. Mine is a 2026 KH10 with the black KH-WL logger/dongle fitted underneath, which has both Wi-Fi and an Ethernet/LAN port.
One thing I wouldn't assume is that because the logger has an Ethernet port it will provide Modbus TCP. On mine, I could access the KH-WL local web interface and give it a fixed IP address, but foxess_modbus still couldn't connect directly over LAN. I scanned the inverter/logger and only found HTTPS on port 443 — there was nothing listening on the standard Modbus TCP port 502.
So if you're getting the connection closed on 443, that doesn't necessarily mean there is anything wrong with the inverter or logger. I don't know of an installer setting that simply enables the local web interface or Modbus TCP, and I wouldn't want to tell you there is one without confirmation from FoxESS.
I eventually stopped pursuing Direct LAN and connected to the physical RS485 pins instead. I'm using a Waveshare RS485-to-Ethernet PoE gateway and that has been completely reliable with Home Assistant/foxess_modbus.
On my KH10 the connections are on the same communications connector used by the CT:
* CT: pins 7 & 8
* RS485: pins 3 & 4
* RS485 gateway: A (D+) and B (D-)
* 9600 baud, 8 data bits, no parity, 1 stop bit
That gives me local access to PV, battery, grid, SoC and inverter controls without relying on Fox Cloud.
If your battery is arriving in five days, I'd probably wait until the installation is finished before drawing too many conclusions about firmware or functionality. More entities/settings may also become relevant once the battery is commissioned.
I also wouldn't buy an EW11/EW41 purely on the assumption that Direct LAN definitely won't work on your particular firmware revision. If you're happy to wait a week or two, it would be interesting to see what firmware you end up with once the complete system has been commissioned.
As for firmware update frequency, I don't know of a published FoxESS schedule. My logger and inverter firmware haven't necessarily updated together either, so I wouldn't assume that a logger update means an inverter update should immediately follow.
If you post your KH10 hardware version, inverter firmware versions and KH-WL/logger firmware version once the battery has been installed, we can compare them with mine. That might actually help establish whether Direct LAN availability is firmware/hardware dependent.
Posted: Tue Sep 08, 2026 6:59 am
by Newbs
I cannot find a hardware version in the app but I have just been prompted for firmware updates
Manager 1.60 -> 1.69
Master 1.64-> 1.71
Slave 1.0.2 -> 1.0.3
Posted: Tue Sep 08, 2026 11:30 am
Thanks Newbs, that's useful.
Those are quite substantial jumps, particularly Manager 1.60 → 1.69 and Master 1.64 → 1.71.
It would be really useful if you could try the LAN connection again once you've installed the updates.
On mine I can access the KH-WL local interface on port 443, but port 502 isn't open, which is why Direct LAN with foxess_modbus wouldn't work and I ended up using the physical RS485 connection instead.
As Will mentioned earlier in the thread that the WL version should have the Modbus server built in, I'm still curious whether this is firmware dependent.
Once you've updated, could you let us know:
* whether you can now open the KH-WL IP address in your browser;
* whether 443 behaves any differently; and
* most importantly, whether port 502 is now open.
If 502 suddenly appears after the update, that would be very interesting and might explain why Direct LAN works on some KH-WL installations but not others.
If it remains closed, then at least we'll have another current KH10/KH-WL installation to compare against.
Thanks for checking.
Posted: Thu Sep 17, 2026 8:08 pm
by Newbs
Apologies for the delay, I didn't see your reply.
After updating the 3 firmware's (which took some time, probably 30 minutes or so) port 502 was still blocked. It may be an upgrade on the "datalogger" that needs to happen - however, I have only seen reports of the built in Wi-Fi allowing modbus over TCP on other Fox Invertors (H1 and H3 come to mind, and the Wifi is described as "integrated" rather than a data logger stick like I have).
Anyway, i bought a PUSR DR164 RS485/Wifi adapter and connected this to the KH10. I now have data in Home Assistant.
Battery is being installed tomorrow - very exciting!
