EPS Wiring and Setting up on 6kW H1 G2 Inverter
Posted: Wed Jul 22, 2026 2:05 pm
Be gentle, first post.
Had the above inverter installed very recently, and I'm considering fitting a very simple output socket fed from the EPS output.
My understanding is as follows
- Grid supply is T-N-CS (PME in old money), so I will need to bond the Inverter and output Earth connection to a 'TT' Earth Rod ?
- Output will require a Type A RCD and 25A MCB ?
- EPS Output requires activating in the Installer's menu, or is it active already, and/or is there an option to have it available at all times (not just during a grid failure )?
