Advice on overcoming Predbat/Foxess-Modbus limitations with KH7 inverter?
Posted: Sat Jul 18, 2026 4:14 pm
by itm60
I am running predbat with FoxESS-Modbus and my new KH7 inverter. I've noticed that FoxESS-Modbus can only put the inverter into one of three work modes:
- Self Use
- Back Up (when Back-Up or Force Charge is selected in FoxESS-Modbus)
- Feed-In Priority (when Feed-in First or Force Discharge is selected in FoxESS-Modbus)
The problem is that, due to the above limitations:
- If Force Charge (Back Up) mode is invoked when excess solar is being generated the excess solar is discarded - it is neither exported nor used to charge the battery
- If Force Discharge (Feed-In Priority) is selected it will not export charge from the battery to take advantage of good export rates unless feed-in limits have been exceeded. It will only export excess solar to the grid.
This means that I lose two major benefits of predbat:
- taking advantage of cheap/free/negative import rates to charge the battery during the day without discarding excess solar energy that is being generated at the time
- taking advantage of high export rates by exporting charge from the battery.
Does anyone have any advice for how/whether I can actually achieve either of the above benefits of predbat, either with or without FoxESS-Modbus?
Re: Advice on overcoming Predbat/Foxess-Modbus limitations with KH7 inverter?
Posted: Sat Jul 18, 2026 4:23 pm
by MaterialBarracuda48
I think you may have to create account to message Nathan under discussions (I see you have now done!)
https://github.com/nathanmarlor/foxess_modbus
or look to see if the solution from Nicois fits your needs better?
https://github.com/nicois/foxess-control
Posted: Fri Nov 06, 2026 9:39 am
by inutopia
What did you end up doing with this?
I've just had a KH8 installed an am frustrated to learn of the restrictions in local control availability and how they impact Predbat.
Posted: Fri Nov 06, 2026 11:16 am
by itm60
I found that the FoxESS-Control integration gives access to more modes on the KH7
Posted: Fri Nov 06, 2026 11:49 am
by inutopia
Great. And these modes are adequate for your needs I guess?
Do you use modbus or the cloud version of the fox-control integration?
Do you use predbat at all?
Cheers
Posted: Fri Nov 06, 2026 1:25 pm
by ChrisGla
Not sure about cloud but with modbus I can confirm "Force Discharge (Feed-In Priority)" definately exports from both battery and solar with Predbat.
I can also confirm that from November stats and the "bonus IOG daytime charges" that the solar isn't being binned. To be 100% sure I'd really need to check again on a bright summer day where solar exceeded EV use (the only time I get daytime charges on IOG)
I did use basic automations as there were a few issues with Predbat for my install in the past around daytime EV charging or at least non-charging dispatches causing peak rate use, but it now seems pretty effective. It takes quite a bit to get Predbat setup properly, I did just use home assistant automations which were almost as effective but the predicted load is useful as i have heat pump now- lets system work out if there is likely to be power to export.
