Reading registers of FOX ESS S2500-G2 Inverter using RS485 Modbus RTU, gives timeout
Posted: Wed Jul 15, 2026 3:09 pm
by async
Hi there.
I'm trying to read some registers (e.g. InvTemperature) of my FOX ESS S2500-G2 Inverter.
The setup is relatively simple:
1) 16-pins COM port of the S2500 is using pins 1 (A+), 2 (B-) and 6 (GND) (conform FOX S2500-G2 Use Manual)
2) Connected via CAT6 wiring pairs to a Waveshare USB to RS485 presented as COM3 on Windows 11
3) Using "mbpoll -a 1 -b 9600 -d 8 -s 1 -P none -m rtu -t 3 -r 28 -c 1 COM3"
Which returns this error:
Read input register failed: timed out
I've tried several different settings like slave ID 247, inter changing PIN1 and 2 and other register numbers. I even measured the voltage of the PINs to exclude wiring faults. Also using different tools like QModMaster gives exact same error.
I extracted the Register information from a Chinese FOX document that I received from FOX Support that I translated to English; so I'm not exactly sure if Input Register 29 of 28 is correct. However, I think I'd receive a return error other than "Timeout" when reading a wrong register?
Anyhow, I can't think of why or where this is going wrong or how to troubleshoot this further…
Anyone with some fresh ideas?
Background info: this is a test setup. Ultimately I want to use HomeAssistant to set an Export Limit register to prevent feed-in charges.
Re: Reading registers of FOX ESS S2500-G2 Inverter using RS485 Modbus RTU, gives timeout
Posted: Thu Jul 16, 2026 9:05 am
Unless Fox have changed it (very recently), the S series does not support modbus inspection of the registers - it may be possible to see the data that is sent to the datalogger on the RS485 lines but that will not be a polled message, it will be a modbus status message transmitted every 90 seconds or so.
There were a couple of projects on github for the T series and from memory I thought the S series could be data harvested that way as well - see here https://github.com/assembly12/Foxess-T- ... -Assistant and here https://github.com/LucasTor/FoxESS-T-series
Posted: Thu Jul 16, 2026 11:30 am
by async
Oh, I see.
I'll ask FOX Support to verify this as they did not specifically mention it in a previous support ticket I raised on this matter.
Anyhow, thanks for your insightfull reaction!
Posted: Thu Jul 16, 2026 12:16 pm
No problem, thanks - please let me know what you hear back from Fox support, at some point it seems logical that Fox will provide modbus access on the S & T series much like their bigger siblings
Posted: Thu Sep 03, 2026 11:38 am
by async
The inverter has been upgraded (from 1.22/0.14/0.29 to 1.36/1.00/1.18 (M/S/A)), and communication with Waveshare RS485/ETH is now working fine. For example, using SGTOOL (which I received from support—still in beta and with a Chinese interface), which allows registers to be read and written.
So this software still uses its own “7f7f wrapping” protocol, although the register blocks 50000–52999 (settings/parameters, R/W) can also be read via Modbus (offset +1).
Anyway, I’m back up and running for now :)
