Homepage reporting errors
Posted: Sun Jul 12, 2026 7:54 pm
by Ukccood
Running parallel inverters F3000 and KH10 on our system. Foxcloud and Android app used to report correctly for over a year until the last month where values now ignore the generation from one of the inverters.
Known issues? Do I sit and wait for fix? Do I have to fix? How does one fix?
Home assistant still reporting happily....foxcloud not so happy 😁
Re: Homepage reporting errors
Posted: Mon Jul 13, 2026 3:35 am
by anthman
Try restarting your wifi router / changing the IP address through your router app/software - fixed it for me.
Posted: Tue Jul 14, 2026 12:30 am
by Ukccood
Not sure how that will help.
Fox cloud 'devices' section can happily see both of my inverters on my system and tell me how much each one is generating. But when you go to 'home' section (diagram with house on it) it doesn't sum the inverter outputs, it only reports the output of 1 device.
Posted: Tue Jul 14, 2026 1:52 am
by anthman
I agree, I was able to update firmware whilst still having the information display problem. I think it may have to do with the data logging part of the system - appreciating it's 3 parts: wifi module, inverter and battery.
If it helps, like it did for me, then that's a positive contribution. Why it works? I don't profess to know the answer!
