Grid offline mode?
Post by Tinsta »
Is there a way of setting the FoxESS invertor to completely ignore the feed from the grid if the battery is 100%, and just use the battery? Mine isn't using the battery even though its 99% charged, still continuing to use the grid?
its set to "self-use", is there a way of simulating a grid outage from the invertor config?
Incidently the load is being mis-reported..nothing is practically on in the house, but its showing as 5.9Kw in use
eg a "Grid offline mode" as seen on the tesla powerwall models.
Re: Grid offline mode?
Post by canton7 »
What sized inverter do you have?
It looks like the inverter is supplying as much as it can, and the grid is picking up the rest
Post by Tinsta »
Inverter Model : H1-3.7-E
Are these the latest firmware versions?
Inverter Hardware Version : -
Master : 1.24
Slave : 1.02
Manager : 1.2
A few weeks ago I got Fox support to update our system and the versions are as follows;
Master : 1.58
Slave : 1.02
Manager : 1.61
Alistair
