Adjust export limit in FeedIn Priority mode
Posted: Wed Jun 24, 2026 3:09 pm
by alexh
I understand the overall export limit for a system is set by the installer and cannot be adjusted by the user (e.g. mine is set to 3.68kw). However, depending the on generation level, in Feed In Priority mode, it would be very useful to be able set a lower export limit so we can split the amount generated between Feed In and battery charging. A simple setting slider in the mode setup would be ideal.
For example, if my system is generating around 3kw, with around 500w running the house, in Feed In Priority mode 2.5kw is exported and no battery charging takes place. It would be great to be able to limit export to less (say 1.5kw) leaving around 1kw to charge the battery.
Any chance this could be added?
Re: Adjust export limit in FeedIn Priority mode
Posted: Thu Jun 25, 2026 10:51 am
by MaterialBarracuda48
If you are feeling adventurous, there is the option of Home Assistant with Modbus (a connection into the Inverter)
There was an update I applied today, that exposes the ability to adjust the export value.
I have not yet played with this, but I suspect it can be adjusted up and down via automations (what Home Assistant is great for)
*Note you should not adjust the export above your legal limits
Posted: Thu Jun 25, 2026 11:27 am
by alexh
Thanks for the info, that may be useful. I tend to like to make small changes on the fly though and am regularly tweeting the system, so for convenience it would be much better incorporated into the app.
I did have access to the export and import limits you showed through the app when the system was first installed, which was very useful, but that disappeared in an update! :?
Posted: Thu Jun 25, 2026 2:21 pm
I am not sure if your needs are enough for a change to be made like this, you probably could just yourself set a more permanent lower export limit and leave it as is.
If you are looking for a more dynamic change, like what you are requesting, then better to take a good look at Home Assistant, so you could make more granular adjustments (if SoC below xx% then you would lower the export rate, if SoC goes above xx% then increase the export rate up to your limit)
Without actually touching export limits, you could do this by setting schedules up right now in the App, So you could have system charge up to xx% in self-use and then have it default back to feed-in work mode after.
Anyway, maybe Fox will look at your suggestion and maybe apply this, but usually they lock the export limits from user accounts.
Posted: Thu Jun 25, 2026 4:41 pm
In case anyone is curious, you can in Home Assistant set an automation to change the export value.
I set a quick one up to change my 3.9kW export to 7000W, at 14:00 it activated.
It was set back to 3900W right after (I was exporting only ~2kW at the time, so didn't breach my limit)
So OP, you can in fact use Home Assistant with modbus to write your own automations to do what you want to achieve.
Posted: Tue Jul 14, 2026 4:14 pm
by alexh
Just to let anyone interested know, I just checked the app and you can now adjust the export limit in Feed In Prioity mode!
Thanks Fox!! :D
Posted: Tue Jul 14, 2026 6:19 pm
alexh wrote: ↑Tue Jul 14, 2026 4:14 pm Just to let anyone interested know, I just checked the app and you can now adjust the export limit in Feed In Prioity mode!
Thanks Fox!! :D
Can you show a picture of this?
As I don't see where you can change the value.
Posted: Tue Jul 14, 2026 6:27 pm
by alexh
Scroll down in the mode setup page, it's at the bottom....
I hope I've actually attached the image....!
Posted: Tue Jul 14, 2026 8:49 pm
I was just checking, as Feed-in work mode has no settings.
It does have settings in the advanced scheduler, and welcome addition.
Posted: Tue Jul 14, 2026 9:03 pm
by alexh
Im on V2.2.18 of the app if that helps, and it is scheduled in the Mode Scheduler, for most of the day when sun is actually generating power, currently 07.00 to 18.00.
