100% battery, solar panels not generating
Posted: Mon Jun 22, 2026 7:59 am
by butters
I have just had 13kw panels installed to accompany my KH9.9 and 42kwh batteries.
I charge the battery with a combination of the solar and 3 hours free energy period during the day.
I have scheduled force charge period which ends at 2pm, after which I am generally at 100% SOC.
My solar should still be generating electricity which could be fed into the grid, however, my solar stops producing and shows 0w on the app.
My export limit is set to 14500.
How do I set it up so my solar continues to produce and feeds the excess back to the grid? I'm keen to export any excess solar production particularly after 4pm when my FIT kicks in and there is still some daylight.
Re: 100% battery, solar panels not generating
Posted: Mon Jun 22, 2026 9:37 am
You can't force charge and export to the grid at the same time, when the batteries are nearing 100% the solar will be throttled (it's been complained about many times but as yet no Fox 'fix').
The only way to get the kind of granular control you want would be to install a home assistant and do everything locally, it is a bit of work but well worth doing in the end.
Posted: Mon Jun 22, 2026 9:40 am
by MaterialBarracuda48
There was a post on the forum a while back (several months) from another Aussie member stating exactly the same issue IIRC.
You may have to do a search in this section to try and locate it, or I might be able to locate it with time.
The work modes of the system seem to curtail the PV once it reaches the 100% SoC.
Are you running with VPP settings?
Posted: Tue Jun 23, 2026 12:01 am
by butters
Not running VPP.
I'm not trying to feed in when forced charge is active.
I'm trying to feed in any excess above the current home use and battery is at 100%.
I have modbus &HA installed. Haven't customised anything as still learning.
Posted: Thu Jun 25, 2026 11:35 am
by TheRoseManCanberra
... i doubt that you're allowed to export at 14.5kw,
I'm in Canberra and single phase, my Export limit is 5kw, my Import limit is 14.5kw
(sure you can vary your Export Limit settings but you will get busted).
Posted: Fri Jun 26, 2026 1:05 am
by butters
Export limit was set by my installer. I haven't changed any settings.
I am on a dynamic connection which I believe limits my connection to a 10kw export.
Posted: Fri Jun 26, 2026 8:43 am
I think It's something in your settings causing your issue.
Here's some screen shots of mine ( a KH9.9, EQ4800-L9, with 11.6 of panels over 2 strings, 5kw DC plus 6.6kw AC) which is very much like your system and set for self-use, and when it cracked 100% it was still exporting around 5kw to the grid.
By the way where are you located and who is your electricity supplier?
