KH10 Grid Import Limit Maxed at 63Amp/14.7Kw since Version 1.69 Master Even though settings are 20kwh/80Amp
Posted: Fri Jun 19, 2026 1:30 am
My system - KH10 63Amp CB, EQ4800 42kw battery, 80Amp House Main Circuit Breaker before when on KH10 Version 1.67 Master could import form grid at around 17.5kwh to house.
After the upgrade to Master V1.69 the max import from grid to house is around 63Amp/14.6kwh. The Inverter has the max import current still set at 80 and max power import still set at 20000W. In fox ess cloud 2.0 i have max ImportPowerLimit 20Kwh.
However the system is clearly limiting import power from grid down to around 63Amp/14.6kwh.
Has anyone else had this issue since upgrading for KH10 to Master 1.69/ Slave 1.03/ARM/Manager 1.64????
Can Fox Ess remove this imposed limit on my house grid load? Which appears to be effecting any KH10 inverter above 1.68 Master firmware level, as confirmed with other users. FOX ESS have no right to limit the power to the house, only that to the inverter.
