Get the device peakshaving settings & 40257
Posted: Sat May 16, 2026 8:02 pm
by gbbsoft
A lot of API is working for me. But I stopped with this issue:
I try to call: /op/v0/device/peakShaving/get
This endpoint has only one parameter: sn
and I receive error: 40257 - Parameter does not meet expectations
Why? Sn doesn't meet exprctations? :-)
Re: Get the device peakshaving settings & 40257
Posted: Sun May 17, 2026 4:30 pm
by gbbsoft
On this issue:
2026-05-17 17:28:04: Foxess: send: json={"sn":"xxx","key":"MaxSOC","value":"25"}, url=https://www.foxesscloud.com/op/v0/device/setting/set
2026-05-17 17:28:04: Foxess: received: {"errno":40257,"msg":"Parameters do not meet expectations. Please reenter","result":null}
2026-05-17 17:28:04: ERROR: 522: Foxess error: 40257-Parameters do not meet expectations. Please reenter
Posted: Sun May 17, 2026 5:12 pm
by gbbsoft
or simple Get:
2026-05-17 18:10:44: Foxess: send: json={"sn":"xxx","key":"MinSOC"}, url=https://www.foxesscloud.com/op/v0/device/setting/get
2026-05-17 18:10:44: Foxess: received: {"errno":40257,"msg":"Parameters do not meet expectations. Please reenter","result":null}
Posted: Sun May 17, 2026 6:05 pm
by alpriest
You get that it if your device doesn't support peak shaving.
Posted: Sun May 17, 2026 6:25 pm
by gbbsoft
Thank. Understand.
Do you know that is this error:
2026-05-17 19:22:20: Foxess: received: {"errno":44108,"msg":"Unrecognized msg:44108","result":null}
Posted: Sun May 17, 2026 8:22 pm
by alpriest
I’ve never seen that. The error messages API should return all known codes, if you’re seeing something not in there then you’d need to reach out to Fox support to ask what it means.
Posted: Sun May 17, 2026 8:43 pm
by gbbsoft
How can I contact Foxess Support who has knowladge about API?
Posted: Sun May 17, 2026 8:53 pm
by alpriest
I’d imagine raise a support ticket from within the fox app, or use the fox website.
