Load graph in Statistics chart showing negative values
Posted: Sat May 16, 2026 11:48 am
Hi FOXESS community,
I am a newbie in this community. This is my 1st post.
I recently installed a H3-15-Smart inverter paired with a CQ6-L7 battery system. I noticed in my load/house hold usage graph in the Statistics chart is always showing negative value, instead of positive, see attached. Is this normal, or does it matter ?
I googled via AI the question and the response was it should be always be showing positive. It is also suggesting this could be due to the direction of the CT clamp, and it would impact the performance of my battery system. I appreciate AI generated responses can be misleading, and my system appears to be working. Thought I should check with the community for affirmation.
Thank you in advance
p/s I have a slab heating system in Melbourne that draws about 12 Kwh when it is on.
