Using battery power only
Posted: Fri May 08, 2026 5:38 pm
by Xbfreedom
Hi there. Can anyone help me? I found instructions on setting up via the app to use battery power only between 4pm and midnight. But when set up even if I turn on the oven during this time our smart meter is showing grid power being used. Can anyone recommend settings so house only uses battery power during these times.
Re: Using battery power only
Posted: Sat May 09, 2026 9:31 am
by MaterialBarracuda48
It would help if you can post the settings that you have for your schedule at this time, and a graph for the power being used. Also what inverter/battery you are using.
In 'Self-use' or 'Feed-in' work modes (typical ones used) the grid use should be minimal.
Posted: Sun May 10, 2026 11:18 am
by Jonesthesteam72
How big an oven are we talking with a kW draw? What else are you using?
How big is your inverter?
