AC grid connector labelling U, W & O? FoxESS H1 6.0E Hybrid
Posted: Thu May 07, 2026 8:22 pm
by John85
Hi folks. I’m installing a Single phase H1 6.0E inverter and looking at the AC grid connection plug, it has 3 terminals labelled with U, W and O respectively. This isn’t referenced in the manual and doesn’t seem to relate to a single or 3-phase connection.
The inverter was purchased some time ago now, so it out of the suppliers support time frame.
Can anyone please help clarify the correct connection or share a photo of an AC connector so I can see which are the L, N and PE pins please?
Many thanks
John.
Re: AC grid connector labelling U, W & O? FoxESS H1 6.0E Hybrid
Posted: Fri May 08, 2026 8:08 am
by daveg
If you put your question to Google Gemini it will explain the lettering correspondence (and the reason for it)
I won't reproduce the answer here since I don't have any expertise to be able to vouch for its accuracy.
Posted: Tue May 12, 2026 10:56 pm
by John85
Hi. Thanks for your reply. Sadly Gemini couldn’t confirm the connection as the letters used on the plug are similar (but not the same) as 3-phase nomenclature, so it confused the AI responses.
SOLUTION:
I managed to find this photo showing the internal side of the connector showing Red, Blue and green/yellow cables.
It therefore translates that:
W= Live
U = Neutral
0 = Earth (PE).
I have confirmed this work and no bad smoke was ejected as a result!
Hope this helps someone else out in the future.
Bw
John.
