HA stopped working
Posted: Wed May 06, 2026 9:25 pm
by Willzs
Hi all
My HA integration has been working without issue but the last few days I just get a connection error and all values say unknown. This is the error it shows:
Error connecting to inverter (friendly name: ""). Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 43; slave: 247 from /dev/ttyACM0: Modbus Error: [Input/Output] No Response received from the remote slave/Unable to decode response
Does anyone know a fix for this?
Re: HA stopped working
Posted: Thu May 07, 2026 10:18 am
by MaterialBarracuda48
Usual quick checks
1. Broken wire(s)
2. Inverter needs restarting
3. HA needs restarting
If that doesn't make it work, then check the finer details on settings.
Posted: Thu May 07, 2026 10:33 am
by Willzs
MaterialBarracuda48 wrote: ↑Thu May 07, 2026 10:18 am Usual quick checks
1. Broken wire(s)
I've tried those things and still get the same issue. I've not changed any of the settings so not sure why they'd effect it?
Posted: Fri May 08, 2026 9:11 am
by rpdasd
Willzs wrote: ↑Wed May 06, 2026 9:25 pm Hi all
What type of inverter ?
I experienced the same with H3 version 2.23/1.93
Posted: Fri May 08, 2026 9:12 am
by Willzs
rpdasd wrote: ↑Fri May 08, 2026 9:11 am
It's a KH8 inverter. What was the fix for yours?
1.60 master, 1.02 slave, 1.58 manager
Posted: Fri May 08, 2026 9:31 am
by rpdasd
Willzs wrote: ↑Fri May 08, 2026 9:12 am
Nothing yet. I think the modbus table changed or the modbus protocol? frame?.
I updated the inverter and HA on the same day, so many variables :\
Posted: Fri May 08, 2026 9:32 am
by Willzs
rpdasd wrote: ↑Fri May 08, 2026 9:31 am
That's what I'm thinking mine is as it was fine before. I've emailed fox and asked the question.
Posted: Fri May 08, 2026 9:38 am
by rpdasd
Willzs wrote: ↑Fri May 08, 2026 9:32 am
possible to reverse-engineer the new table, but "aint nobody got time for that" :D
Posted: Fri May 08, 2026 10:31 am
Willzs wrote: ↑Fri May 08, 2026 9:12 am It's a KH8 inverter. What was the fix for yours?
KH7 with same FW versions for me, and Modbus is working as normal here.
Posted: Sun May 10, 2026 4:33 pm
by Willzs
So it turns out there was a small break in my cable run :roll: It was hidden behind another cable it runs along with. Thanks for all your help.
Posted: Sun May 10, 2026 5:42 pm
Willzs wrote: ↑Sun May 10, 2026 4:33 pm So it turns out there was a small break in my cable run :roll: It was hidden behind another cable it runs along with. Thanks for all your help.
Good of you to come back and let everyone know.
Hopefully all good now.
