After a month in use I am soon to start getting paid for exporting yippee ....I have already given away over 500kWh for free
I would like to reset / zero the total export / total revenue to grid figure so as to start again....can this be done and if so how?
Also, I cant seem to enter the FIT of 12p /kWh with Octopus....am I missing something ?
Re: export reading and rates
Posted: Thu Apr 30, 2026 7:02 pm
by MaterialBarracuda48
Congrats on getting your export MPAN, shame about the 500kWh
I don't think you can reset anything yourself, and I would personally recommend you create a spreadsheet to track import/export values. Reason being, if in the future the 12p export becomes 6p for example, the system is too dumb to apply the change on dd/mm/yyyy... so it applies it to every single kWh exported.
Posted: Thu Apr 30, 2026 7:13 pm
by davidwf15
Oh dont worry..... there will be plenty of spreadsheets
Posted: Sat May 02, 2026 9:47 am
by davidwf15
another question.... on the dashboard, although I see a total revenue generated amount it says no tariff.....
and I cant see anywhere to amend it apart from in here settings
Screenshot 2026-05-02 094947.jpg (10.61 KiB) Viewed 14846 times
is this correct?... I am on Octopus @12p / kWh
Posted: Sat May 02, 2026 10:24 am
I have mine set at 0 so that it doesn't show to me some random value for Total Revenue that is bogus.
Will does have a good selection of videos on his channel for many subjects
Posted: Sat May 02, 2026 11:13 am
by davidwf15
thanks...now sorted
@MaterialBarracuda48: ...... deleting the existing tariff did in fact clear out all the entries as desired
Posted: Sat May 02, 2026 12:15 pm
Perfect
Posted: Sat May 02, 2026 12:36 pm
by davidwf15
Finally got the solar FIT sorted.....during the summer months - potentially March to October and beyond - the system should give us totally free electric day and, with the battery being charged up during the day, free night electric saving at least £130 of grid draw and produce at least £60** a month FIT.... with a £10k initial outlay it should give a payback period of 5 years and then produce £2k a year income saving year on year ......wow
So far - and its only been in for the month of April - we have produced 1.03 MWh, self used 511 kWh, exported 508 kWh and used around 96kWh at 6p /kWh (£5) from the grid overnight for my sons' EV ....if every house did that and of course it was sunny every day we wouldnt need a grid at all !!!
** should be higher, that was Aprils' figure which we didnt get paid as they hadnt set it up yet
pretty impressive so far........its nice having the option to do the washing / dishwasher / tumble dryer / cooking any time of day without really thinking about it, so far the battery has remained above 20% charge altough obviously in winter it probably wont charge fully during the day.....but we can top it up overnight at 6p /kWh which, once that orange idiot has finished bombing the middle east will hopefully come back down to 5p or less
Posted: Mon May 04, 2026 11:15 pm
by davidwf15
Still getting to grips with all the options and settings .......unless I am mistaken I think i would be better off charging the battery overnight at 6p/kWh (EV rate) and exporting anything the house doesn't use uring thd day for FIT payment.......I am assuming the PV generation priority would be house use, battery charging, export
What would be the easiest way of doing this ?...setting a charge schedule?
Posted: Tue May 05, 2026 8:56 am
davidwf15 wrote: ↑Mon May 04, 2026 11:15 pm
That’s what I do, I charge overnight on low tariff and leave the workmode set to Feedin - you can either schedule it to happen first thing in the morning and back to Self Use at night, or as I do at this time of year I just leave it in Feedin as the inverter will always meet house load overnight.
Posted: Tue May 05, 2026 9:07 am
by davidwf15
great, thanks.... I am also trying the capture AI program to see how that fares...
Any experience or tips with that ?
Posted: Tue May 05, 2026 11:26 am
I would second the charge overnight, and feed-in tariff for the daytime with one note.
If your export limit is low, then your PV output will be capped, so you may have to make some room in the battery to store the excess.
I have 6.16kWp and a 3.9kW export, so on good solar days, your PV would be capped out. If you have room in your battery, it can mop up the overspill.
What is your export limit, if it is high enough, then you won't need to worry about this.
Posted: Tue May 05, 2026 11:28 am
by davidwf15
It's 5kWh
Posted: Tue May 05, 2026 11:35 am
Odds are you should charge overnight to 100%, and when your cheap period ends, a cheeky little discharge for 30-45mins to lower the SoC so it can mop up the solar above 5kW.
Posted: Sat May 09, 2026 9:23 pm
by davidwf15
I am trying the AI program......it appears to be working but I am not convinced correctly....surely it should FULLY charge the battery on the overnight 7p/kWh rate.....it isnt doing so
