Additional battery query
Posted: Thu Apr 30, 2026 10:32 am
by gxaxrxy2025
Hi all
I am looking to add a battery to my current set up.
The battery I have is a Fox EP5 and I have two questions
Q1) As I have a 5kw battery can I only add other 5kw batteries? So if I wanted an additional 10kw I would need to add two 5kw batteries.
Q2) Is it true that I can only add another EP5 or can I add any make/brand?
Thanks in advance
Re: Additional battery query
Posted: Thu Apr 30, 2026 10:56 am
by MaterialBarracuda48
Posted: Thu Apr 30, 2026 9:30 pm
by gxaxrxy2025
Thank You
But if an installer was to offer me a different branded 5kw battery would it work with the Fox EP5?
Posted: Thu Apr 30, 2026 10:00 pm
gxaxrxy2025 wrote: ↑Thu Apr 30, 2026 9:30 pm But if an installer was to offer me a different branded 5kw battery would it work with the Fox EP5?
I would not do that at all, and you would invalidate your warranty... assuming you don't create a fire :!:
Stick with the Fox kit.
Posted: Thu Apr 30, 2026 10:02 pm
by gxaxrxy2025
Will do
Posted: Thu Apr 30, 2026 10:11 pm
You will need to use 'Fox ESS EP Junction Box' of course to wire up 2 or more batteries, best of luck with the upgrade.
