FoxESS - Battery query
Posted: Mon Apr 27, 2026 8:22 pm
by Jlbaxter0
I have solar panels, a battery and inverter.
I've tried to set it up so the battery is force charged overnight during off peak cost (would only let me specify 00:00-05:30 as couldn't do 23:30)
Outside of these times it prioritises 'Self-use'
My battery is currently showing a SOC of 75% but remaining energy shows 0kWh, shouldn't the SOC match the energy and be 0% if this is the case?
System min SOC is set at 10% (unchanged)
Backup cut off SOC is set at 10% (unchanged)
Unsure how to add an image so have described as best I can
Re: FoxESS - Battery query
Posted: Tue Apr 28, 2026 9:00 am
by MaterialBarracuda48
Jlbaxter0 wrote: ↑Mon Apr 27, 2026 8:22 pm Unsure how to add an image so have described as best I can
Take a look here at a previous post of mine
viewtopic.php?p=14205#p14205
Posted: Tue Apr 28, 2026 11:17 am
by Jlbaxter0
MaterialBarracuda48 wrote: ↑Tue Apr 28, 2026 9:00 am
Thanks!
Posted: Tue Apr 28, 2026 12:34 pm
It might be an idea to check your Inverter/Battery/Datalogger Firmware against the list provided by Will
viewtopic.php?p=8069#p8069
Not saying this is a fix, but missing items can be down to duff FW (old)
The FoxCloud2.0 App can show your firmware versions loaded currently, if you click on the serial number for each, and depending on system, you can update via the App if supported (best take screenshots before ANY upgrades)
