SG connection?
Posted: Sun Apr 26, 2026 3:47 pm
by guyliddell
Dear Fox ESS Technical Support,
I am having a Fox ESS H1 hybrid inverter installed as part of a solar PV and battery storage system. I wish to connect the H1 to a Vaillant aroTHERM Plus 7kW heat pump (controller: sensoCOMFORT VRC 720f/3) using the SG-ready protocol, and I would be grateful for clarification on the following points.
1. Does the H1 have a built-in dry-contact relay output for SG-ready signalling? If so, which terminals are used and what are the contact ratings?
2. If no built-in output is available, what Fox ESS accessory or external relay module is recommended, and how does it interface with the H1?
3. How is the SG-ready output configured — via the Fox ESS app, local inverter display, or firmware parameter — and what conditions (surplus generation level, battery SoC) trigger State 2 (encouraged) and State 3 (commanded) signals?
4. What signal cable specification (voltage, core count, cable type) is appropriate for the two-wire run between the H1 and the heat pump SG-ready input terminals?
5. Is there any known compatibility issue between the Fox ESS SG-ready output and the Vaillant VRC 720f/3 SG-ready input?
Any relevant wiring diagrams, application notes, or commissioning documentation would be appreciated.
Re: SG connection?
Posted: Mon Nov 16, 2026 3:06 pm
by Yahya25
Hi, hope you're well. Did you find the answer to these? I also have a H1 inverter and have just had a Samsung ASHP installed so would be interested in learning about this. Thanks.
Re: SG connection?
Posted: Mon Nov 16, 2026 10:27 pm
by guyliddell
Not a thing. Still waiting for any reply…
Re: SG connection?
Posted: Mon Nov 16, 2026 10:48 pm
by nrb501
On the H1(G2) there are two dry contact outputs, on the "meter/ct/rs485" connector pins 10 & 11 and 12 & 13. Both are configurable for SG-ready1 or SG-ready2 through the installer advanced settings "DryConfigure" and "SgReadyConfigure", note 10 & 11 is by default set for switching an external EPS contractor. Unsure of the contact ratings as no info in the manual, would guess about 240v/100mA max.
Your other questions I am unable to answer as I've not used this function. Some details are given in the H3Smart inverter manual
Re: SG connection?
Posted: Tue Nov 17, 2026 1:54 am
by guyliddell
Thank you!
Where's the manual you refer to please?
Re: SG connection?
Posted: Tue Nov 17, 2026 8:35 am
by nrb501
All the manuals are at https://www.fox-ess.com/download
Information about the SG-ready function does not seem to have made it into the H1(G2) or KH manuals yet so whether the function is fully available likely depends on the latest firmware being installed. The settings are there and can be set on the H1(G2) with master/manager v1.61/1.82 I can't comment on earlier versions so YMMV
