H1-6.0-E-G2 + Elfin EW11 on RS485 causes wallbox communication fault
Posted: Wed Apr 22, 2026 4:31 pm
Hi all,
I have a FoxESS H1-6.0-E-G2 inverter, W6 dongle, ECS2800 batteries and an A7300P1-E-2-WO wallbox.
I installed an Elfin EW11 on inverter RS485 pins 3/4 for Home Assistant using foxess_modbus. The Elfin works fine and HA reads the inverter correctly.
But when the Elfin is powered on, the wallbox shows an external meter / RS485 communication fault and the EV does not charge. If I power off the Elfin, charging works normally again.
So it seems I can have HA monitoring or wallbox charging, but not both.
Has anyone had the same issue or found a solution?
Thanks.
Thanks.
