Cannot Charge Past 97pc
Posted: Mon Apr 13, 2026 8:07 am
I have a H8 inverter with 47kwh battery installed about 3 weeks ago and for the life of me I cannot get my battery to reach 100pc. It tops out at 97pc about 10am and it hadn't budged since.
I have an image from the FoxCloud app and figures from the modbus dongle export.
Even when I schedule a force charge, its still uploading to the grid. What is going on here??
-- Modbus Sensors
Ambient Temp (Inverter) 48.8 °C
Battery Charge (Inverter) 0.00 kW
Battery Charge Today (Inverter) 5.00 kWh
Battery Charge Total (Inverter) 123.60 kWh
Battery Discharge (Inverter) 0.41 kW
Battery Discharge Today (Inverter) 7.40 kWh
Battery Discharge Total (Inverter) 257.40 kWh
Battery SoC (Inverter) 97%
Battery SoH (Inverter) 100%
Battery Temp (Inverter) 40.4 °C
BMS Cell mV High (Inverter) 3,375 mV
BMS Cell mV Low (Inverter) 3,359 mV
BMS Cell Temp High (Inverter) 30.8 °C
BMS Cell Temp Low (Inverter) 26.9 °C
BMS Charge Rate (Inverter) 25.00 A
BMS Discharge Rate (Inverter) 50.00 A
BMS kWh Remaining (Inverter) 46.08 kWh
Connection Status (Inverter) Connected
CT2 Meter (Inverter) -0.00 kW
Feed-in (Inverter) 0.00 kW
Feed-in Today (Inverter) 23.70 kWh
Feed-in Total (Inverter) 71.50 kWh
Grid Consumption (Inverter) 0.04 kW
Grid Consumption Today (Inverter) 0.30 kWh
Grid Consumption Total (Inverter) 4.00 kWh
Grid CT (Inverter) -0.04 kW
Input Energy Today (Inverter) 0.20 kWh
Input Energy Total (Inverter) 2.10 kWh
Inverter Battery Current (Inverter) 0.80 A
Inverter Battery Power (Inverter) 0.41 kW
Inverter Battery Voltage (Inverter) 486 V
Inverter Current (Inverter) 1.30 A
Inverter Fault Code (Inverter) None
Inverter Power (Inverter) 0.26 kW
Inverter State (Inverter) On Grid
Inverter Temp (Inverter) 44.1 °C
Load Energy Today (Inverter) 4.60 kWh
Load Energy Total (Inverter) 192.00 kWh
Load Power (Inverter) 0.29 kW
Max Charge Current (Inverter) 5.00 A
Max Discharge Current (Inverter) 50.00 A
Max SoC (Inverter) 100%
Min SoC (Inverter) 10%
Min SoC (On Grid) (Inverter) 10%
PV Power (Inverter) 0.00 kW
PV1 Current (Inverter) 0.00 A
PV1 Power (Inverter) 0.00 kW
PV1 Power Total (Inverter) 0.000 kWh
PV1 Voltage (Inverter) 2 V
PV2 Current (Inverter) 0.00 A
PV2 Power (Inverter) 0.00 kW
PV2 Power Total (Inverter) 0.000 kWh
PV2 Voltage (Inverter) 2 V
PV3 Current (Inverter) 0.80 A
PV3 Power (Inverter) 0.00 kW
PV3 Power Total (Inverter) 14.031 kWh
PV3 Voltage (Inverter) 274 V
PV4 Current (Inverter) 0.60 A
PV4 Power (Inverter) 0.00 kW
PV4 Power Total (Inverter) 14.917 kWh
PV4 Voltage (Inverter) 219 V
Solar Generation Today (Inverter) 34.90 kWh
Solar Generation Total (Inverter) 331.00 kWh
Version: Manager (Inverter) 1.58
Version: Master (Inverter) 1.6
Version: Slave (Inverter) 1.02
Yield Today (Inverter) 28.50 kWh
Yield Total (Inverter) 260.60 kWh
-- Modbus Sensors
