Stop export to grid
Posted: Tue Apr 07, 2026 11:43 pm
Hi, I just had battery installed and added a AC couple inverter to battery which overrides the existing inverter. After reading specs, I want to share with everyone a tip. The settings in your fox ess battery is set at 14500. Export to grid.. I set mine to 0000.. so my 13.2 solar panels charge house, power store hot water and battery. I set it to run fully off-grid and not draw from battery.. it goes up to 75-95% depends on weather and down to 20% after Ev car draws 6.5kw for 2 hrs.
If my battery goes under 10% it draws from grid..
I can't understand why people want to export to grid for 3 cents kw or charge battery at night with grid ??
The electricians just install and go.. make sure U set your inverter to stop export if that's what U want.. cheers
I basically off grid
