Second inverter integration with Hime assistant
Posted: Mon Apr 06, 2026 3:38 pm
by jonathanb48
I’ve just had my second inverter installed which should now mean that I can charge my batteries to 100%. My installer tells me that it has been installed as a slave to the primary inverter ( it is exactly the same as the first inverter giving me 12 kw of charging capacity) . Does this mean I don’t need to integrate this second inverter with home assistant separately? And the home assistant automations should still run but for both inverters ? Thanks for the help on this
J
Re: Second inverter integration with Hime assistant
Posted: Mon Apr 06, 2026 5:07 pm
I’m not entirely sure on the parallel operation, Will would be better answering that question, in principle if one is told to force charge I would expect both to follow - but if you want to see independent sensors for each inverter, the statistics, charge/discharge etc.. you’ll need to have both inverters being monitored by home assistant via modbus.
Posted: Tue Apr 07, 2026 1:24 pm
by jonathanb48
It didn’t seem to work but am not sure that this was an errror or whether my installer has got the settings wrong - I do know that my installer has set up a schedule without telling me and that has messed up my home assistant and am now back to trying to fix the fragile work scheduler.
I don’t presently have a stable environment to test the two inverters but do still want to try and integrate both and control them with HA rather than the fox app
