Anyone installed a FoxESS EQ4800 battery / KH9.9 Inverter in Canberra, Australia
Posted: Mon Apr 06, 2026 10:05 am
by TheRoseManCanberra
We had our FoxESS EQ4800-L9 battery with a KH9.9 Inverter installed late December 2025 and i was just interested in whether others around Canberra may have done the same or similar, and also whether anyone would be interested in swapping installation experiences??
Here in Canberra in the last few months we have gone from +40c days to close to zero-C and likely to go minus very soon. Maybe there's a chance of swapping ideas to help us all in operating our systems during the large variations of our local climate.
FYI My experience so far with the Inverter/Battery combination and it's operation have been quite good, but my experience with the quality of the installation thru the supplier / installer / certifier chain have been less than what i would have expected, and i'm still in the process of trying to get things rectified. I will go into this in more detail if there is interest.
Re: Anyone installed a FoxESS EQ4800 battery / KH9.9 Inverter in Canberra, Australia
Posted: Tue Apr 07, 2026 12:35 am
Sunny day here in Canberra this morning after a couple of days cloudy with rain, nice to see the sun again, battery got down to 13% overnight but looking outside should be heading for full again early afternoon.
Posted: Tue Apr 07, 2026 12:40 am
Yes that's my setup, KH9.9 Inverter with EQ4800-L9 Battery stack, these are being fed from my existing two previously installed solar panel sets totaling 11.6kw.
Posted: Sat Apr 11, 2026 12:18 pm
by cjau
Yes, I've got one installed in Canberra, but it is KH10. I also have one in Brisbane, that is KH9.9.
Posted: Sun Apr 12, 2026 3:22 am
Hi cjau, thx for the response. I guess I’m interested in how yours and others have been performing, interestingly mine has been running (I say this holding my breath) extremely well since we started on 5th January 2026. I’ve been a bit underwhelmed with our supplier/installer/certifier chain, trying to get someone back to fix a couple of installation fails, dodgy earth-wire connection and poorly secured battery-stack…… see pics attached… am I being too picky?….. just not the quality I would have expected. I’ll be making another contact attempt this coming week.
Anyway, how’s yours been going?… any pics you could share? I’m thinking about installing a hood of some sort to give a bit of extra protection. Any ideas you have would be much appreciated.
Posted: Sun Apr 12, 2026 10:11 pm
by cjau
That earthing wire join does look dodgy and probably not to code!
I think my installer seemed to do a pretty neat and careful job, but maybe I need to look more closely at all the connections! I'm not there at the moment, so don't have photos.
I guess the problem is that the battery companies contract electricians to do the installs, and some will be better than others. The first company I tried to buy battery from had difficulty finding an installer in Canberra, and then ended up going with a different company.
Currently my battery is exposed to sun on west, but hopefully will end up putting up a carport and it should be under cover.
Been very happy with performance so far. My main issue is with the original solar install from two years ago and not having export limiting setup. Also shading on panels in winter leads to low performance in winter especially. Trying to get some more panels in better location now that I have battery and extra string, and get everything moved over to my new FoxESS inverter. I didn't realize before how all the rules worked before otherwise would have pushed harder to get that done at time of battery install. For EVO Energy on single phase with battery allowed to have two inverters but only one inverter can have panels connected. Can have as many panels as inverter can handle.
Did you get a backup circuit installed? Original quote I got had it as included, but didn't realize until too late that it wasn't included in later quote, and was going to cost $800+ extra (can't remember exactly how much). In my Brisbane install the setup was too complex so I didn't get it done, as usually the included backup was just two circuits. I was recommended by my Brisbane installer to make sure I keep the connector for the inverter for backup setup, in case it was hard to source later.
Posted: Mon Apr 13, 2026 10:44 am
Yeah i've just tried calling the electrician again re the dodgy-earth connection, went to voicemail as usual so if i don't get a response by tomorrow i'll email his company (not too worried about this).
Anyway, yes if you have a westerly facing install it really should have some protection, i saw a piece recently of how a guy put a couple of large brackets on his wall and attached a large piece of shade-cloth over the top and down to just about ground-level so i guess that a good cheap way of getting some weather protection. My install is on an east-facing wall under the eaves with large hedging-trees about 2mtrs away so it gets some protection as-is but I'm still going to put up a hood or similar (i did this on my hot-water heat-pump just for some protection which is on a north-facing wall).
I was also unfamiliar with Evo's rules and have put my faith(?) in the electrician to do the right thing for my new installation. I also had 2 solar panel systems running, a 5kw system installed in 2013 and an additional 6.6kw system installed in 2018, both have run flawlessly over the years, and both were unrestricted in exporting notwithstanding visits by ActewAGL and their contractors installing and then replacing smart-meters. Over the years we exported an incredible amount of kWh's each quarter and no-one ever questioned it.
On my roof i have 20 panels facing due-north (5kw) and another 20 panels split facing east and west (6.6kw), little to no shading effects. As i understand it the electrician disconnected my original 5kw inverter and connected the panels into the new Fox 9.9 inverter, with the other 6.6kw system also connected to the new Fox 9.9 inverter, all seems to be running fine. I've checked the systems since the Fox install and it looks like i haven't lost power from the panels so I'm happy with that.
No Backup. Got shafted on this, was promised verbally that i would have 'backup' but on installation day Kamal, the 'owner' of the supplying company (Prime Solar Energy, ACT) said as it wasn't written in the quote then no-go (at this time and ever since the salesperson Ikhvan? could not be contacted), felt at the time like telling them to take their shit and go but as i did get it at a very reasonable price i figured it wasn't worth getting too heated about, maybe at a later date, but that's another thing i want to ask the electrician about if he ever gets back to me. It makes me feel a bit better if i tell myself we don't get many grid-power outages these days.
Just one question, i didn't quite understand, you mentioned 'export limiting setup' issue, what did you mean by that?
Posted: Mon Apr 13, 2026 1:10 pm
by cjau
TheRoseManCanberra wrote: ↑Mon Apr 13, 2026 10:44 am
I also had 2 solar panel systems running, a 5kw system installed in 2013 and an additional 6.6kw system installed in 2018... On my roof i have 20 panels facing due-north (5kw) and another 20 panels split facing east and west (6.6kw), little to no shading effects. As i understand it the electrician disconnected my original 5kw inverter and connected the panels into the new Fox 9.9 inverter, with the other 6.6kw system also connected to the new Fox 9.9 inverter, all seems to be running fine.
Sounds like when it is time for you to replace your panels you could get double the kW, since panels get more W per area now. If you can use the extra KWh. I got 30 panels for 13.3kW installed in 2023.
On good days, how many kWh do you get at peak summer compared to lowest winter?
No Backup... but as i did get it at a very reasonable price i figured it wasn't worth getting too heated about, maybe at a later date, but that's another thing i want to ask the electrician about if he ever gets back to me. It makes me feel a bit better if i tell myself we don't get many grid-power outages these days.
Yes, I thought since we hardly ever have outages no backup is not that big a deal for now. But would have been nice...
.. both were unrestricted in exporting notwithstanding visits by ActewAGL and their contractors installing and then replacing smart-meters. Over the years we exported an incredible amount of kWh's each quarter and no-one ever questioned it...
I also had no export limits on original install. The required metering device was in the paperwork, but it's not there now. I don't know if it never got installed, or if it got lost somewhere along the way. My 2023 install was by Canberra Solar Shine who were pretty dodgy, not paying people, including my electrician who upgraded my meter box, even though they got money from Brighte loan. My new FOX battery and inverter was AC coupled so there was still no export limiting. I contacted EVO to find out what I was allowed to do in terms of extra panels and inverters (I was hoping I could add extra panels to my new inverter and leave my existing panels with old inverter), and they noticed I was often exporting more than 5kw and said I needed to fix it immediately or turn off until fixed. When I tried to do that I found out my old inverter was not capable of export limiting and so now need to move all my panels over to new inverter. In the interim I have had to cap all generation from my old inverter so that it doesn't end up exporting more than 5kW.
Posted: Tue Apr 14, 2026 5:36 am
My older (2013) system was 1 x Aurora Uno Power One 5kw Inverter with 20 x 250w Canadian Solar Panels, the newer (2019) system is 1 x Fronius Primo 5kW inverter with 20 x 330w Jinko Tier1 Panels, both the systems performed amazingly well with no issues whatsoever since they were installed. The Aurora system was installed as a 'Gross-export' system so everything it produced was exported to the grid for FIT, the Fronius system was installed as a 'Net-export' so it fed the house first and then anything left was exported.
When the electrician came to finalize the Fox installation, we had a chat and at the time he said to me that i was currently exporting >9kw to the grid and that it should be limited to 5kw in accordance with the Evo energy policy for exporting, i told him my story about uncapped exporting since 2013 and he looked puzzled, anyway he changed the Export Limit on my Fox Inverter to 5kw and that's where its been ever since, except when i changed it up or down a couple of times to see what happened.
I looked into what i've been exporting over the last 12 months and while i don't have actual kWh's at the time of day i did come up with the following Qtly Usage & Export figures, and overall average net-export per day came to around 36kWh.
Battery final connection on 5th Jan 2026
Feb26 301 3482
So your system sounds like mine was, i also couldn't end up with 3 inverters so i asked the electrician to remove my oldest Aurora inverter, which he has disconnected but not yet removed from the wall, promised he'd be back to do that! So these 5kw of solar panels he's connected (directly?) to the new Fox inverter and it's production shows as 'Solar' in the FoxCloud app, the Fronius 6.6kw system runs as usual except that it also feeds into the Fox inverter, with it's output showing as 'Gen.Load' (strange name but there you go). To cut a long story short i guess you need to get your systems connected to the Fox inverter like mine.
Posted: Fri Apr 24, 2026 9:52 pm
by cjau
Yes, with everyone madly doing battery installs I think it is hard to get an installer to do anything at the moment except try and install a battery!
Thanks for the extra info. I was wondering more about how much your system generates in summer as opposed to winter. Not the export amount, but total generated. So if you have time to share, maybe the total generated for lowest month (June?) and total generated in highest month (Dec or Jan)? Perhaps the different totals for each system?
Because of shading, and some south facing panels I have a big difference between summer and winter. Eg Dec 2025 my panels generated total of 2328 kWh and June 2025 it was only 396.5 kWh. I hadn't looked closely until I got my battery, and didn't realize how bad my winter problem was!
Posted: Sat Apr 25, 2026 12:06 am
by suti
I'm not in Canberra, but something Canberrans should take into account is that batteries don't like the cold. Below 16C and the charging rate goes to about 70% of your inverter max (this is my experience in Sydney). Below 11C it is supposed to charge lower still. Even if your electricity provider gives you free charging in the middle of the day, you may find yourself not being able to charge at all if it is 0C.
More info from a video 12 months ago:
Posted: Sat Apr 25, 2026 1:02 am
by cjau
Thanks for the heads up. Will have to keep an eye out as going into winter! I was wondering about charging between midnight and 7am, when there are off-peak rates, but could be an issue in winter...
Posted: Sat Apr 25, 2026 2:30 am
cjau, here's the additional info you were asking about, figures from my Fronius Primo5 inverter (split system 6.6kw panels East-West facing) for Dec25-Jan26, plus June25, these are all daily figures and while it might say 'export to grid' anything after 5th January '26 was going to my battery. With my other system the Aurora UNO PVI5000 (North facing 5kw panels) (limited monthly figures) it was always a 'Gross-Export' system so everything went directly to the grid. Pic of my roof included.
Posted: Sat Apr 25, 2026 3:03 am
...those images look poorly, ill try to get better ones later.
Posted: Sat Apr 25, 2026 12:01 pm
cjau, Try these... hope its what you're looking for. Anyway, my EQ4800-L9 battery is usually full by early afternoon so i can't complain, it's just charging from my panels, keeps us running on battery from then until next morning when it might be down around 75-80% then charges up again. We did run it down once to 13% after a big weekend at my place where we had to run the dishwasher about 5 times and this was also over a couple of very cloudy days.
I'm actually really happy with how it's been performing so far.
Posted: Sat Apr 25, 2026 1:35 pm
by cjau
Looks like on a good day in Jan your East-West panels generate 43kWh, and in June the best day is about 17kWh (about 40% of 43kWh). For your North facing panels 865kwh for whole of Dec, around 400 kWh for Jun/Jul (about 46% of 865kWh). That's helpful. Gives me an idea of best I can expect for winter output.
Sounds like you have heaps to spare in your battery. Maybe you can find a plan to sell some during peak hours? Or get an EV to charge at night.
Posted: Sun Apr 26, 2026 1:45 am
Thx, yes we do have ample capacity and we still run gas heating with a plan to change that to ducted electric, same for the pool, we will be adding a heat pump to that to heat it a little. Cold here this morning around 3-4°, sunny so the battery will be full by lunchtime.
Posted: Mon May 18, 2026 1:39 pm
by cjau
suti wrote: ↑Sat Apr 25, 2026 12:06 am
I noticed on cold days recently there was an alert on my app for "Low Temperature". At the time it would only allow maximum charging of about 3.3kw.
Posted: Sat Jun 06, 2026 7:25 am
Yes been getting some cool temps in CBR but not too bad at present, generally around 5-6c but this morning was around -2c. If it's clear skies like today then we are ok.
Got my first full Qtly electricity bill having the battery for the full 3 months, happy to say our usage on a TOU plan only cost $21.73 including gst, next qtr will be full-on winter so likely not so good.
Posted: Mon Jun 08, 2026 3:48 am
by cjau
TheRoseManCanberra wrote: ↑Sat Jun 06, 2026 7:25 am
I've change to an EV plan and get $0.12c/kwh between midnight and 6pm. Charge car and battery during that time, as my solar is really weak in winter.
Posted: Wed Jun 10, 2026 5:26 am
..but that's not in CBR, right?
Posted: Wed Jun 10, 2026 3:16 pm
by cjau
TheRoseManCanberra wrote: ↑Wed Jun 10, 2026 5:26 am
Are you asking about the EV plan? Yes, with ACTEWAGL. You need to have an electric vehicle. Another option could be Amber. You can also connect with Origin Battery Lite plan and they will give $200 credit, but maybe you don't have control of your battery for forced charging etc. You can change to someone else after you received your credit.
