Delete a Forced Charge Schedule Set Up using Old Fox Cloud App
Posted: Wed Apr 01, 2026 4:01 pm
by Malc
Hi - I set up a forced charge schedule on my system to make use of a less expensive overnight tariff last October using the Fox cloud App. I now want to cancel the schedule as it's better to use the sun to charge the battery. I went to the app only to find I couldn't see the the schedule I set up (I know that it is still charging overnight though). Since last October the app has been updated to Foxcloud 2.0. I have watched Will's video online which expalns how to access the new mode scheduler in Foxcloud 2.0 but I still can't see my old schedule. How do I access this to cancel it. Rgds
Re: Delete a Forced Charge Schedule Set Up using Old Fox Cloud App
Posted: Wed Apr 01, 2026 4:25 pm
by MaterialBarracuda48
Login to the website using your credentials
Then under Quick Settings top right, find this Grid Charging Time section and disable these if active.
Link to Jem's post with picture.
viewtopic.php?p=15385#p15385
You can also check Work Mode and the Mode Scheduler in this location.
From a financial point of view, if your night import is less than your daytime export price, you are better to charge each night.
