Fox A Series Charger A7300P1 series modbus mapping?
Posted: Tue Mar 31, 2026 1:14 am
Hi all,
I’m trying to integrate my Fox ESS EV Charger with Home Assistant using Modbus TCP and I’ve made some good progress, but I’m stuck on finding the correct register(s) for enabling/disabling charging.
### What’s working
* Modbus TCP connection is working fine
* I can successfully read:
* Charger connected status
* Charger power
### What I’m trying to achieve
* Turn charging **on / off**
* Control:
* Start / stop charging remote (as I know it needs this otherwise you still have to tap rfid card)
* Adjust max current so I can increase or decrease amps dynamically
### What I’ve tried
* Tested coil writes (e.g. address 400, 409, 413) → no effect
* Tested nearby holding registers around the working current register (e.g. 527, 529, 530, 531, 540, etc.) with values 0, 1, 2 → no effect
* Confirmed writes succeed (no errors), but charger does not react
### My question
Has anyone successfully:
* Found the **enable / start / stop charging register(s), adjust current ** for a Fox ESS EV Charger?
* Or confirmed whether this control is **not available via Modbus TCP**?
If you have a register map, working config, or even partial info, that would be hugely appreciated.
Thanks in advance!
### What’s working
* Charger power
* Control:
### What I’ve tried
### My question
Thanks in advance!
