Toggling the forced charge period.
Posted: Mon Mar 30, 2026 3:37 pm
by jem
About a month ago I set the batteries to charge from grid between 3am and 5am. I now want to switch this off as Solar is producing enough for me. However, it seems the app has changed and I can not find the toggle anymore. I have read many of the forums with similar topic and have learnt how to schedule a "forced charge". However, this does not tell me how to switch the old schedule (pre new App) to switch off! Anyone out there who has solved this? Many thanks
Re: Toggling the forced charge period.
Posted: Mon Mar 30, 2026 3:50 pm
by Will
You'll need to use the desktop version to disable this old charging slots and use mode scheduler going forward.
Posted: Mon Mar 30, 2026 10:15 pm
by jem
Thanks for the prompt reply Will.
So I am using desktop and it seems the same as the app. There was no scheduled battery charging to see. I am very conscious that I may be in the wrong area (I had to go to the "new version available button" to even see any battery setting info by the way). Im doing something wrong, can you give me more help please?
Im very grateful for your time.
Posted: Mon Mar 30, 2026 10:17 pm
by jem
Sorry, one image shows that I have newly added a scheduled battery charge just to see if by toggling on and off it will override the original timed charge.
Posted: Mon Mar 30, 2026 10:23 pm
by MaterialBarracuda48
"Grid Charging Time" at the top of the quick settings is where you find the basic timed charge.
Posted: Tue Mar 31, 2026 8:29 am
by jem
Thanks MaterialBarracuda. Before I read your message, I restarted my system. Perhaps this is why I see this in charging now.
Posted: Tue Mar 31, 2026 9:57 am
That looks like it should work now, have to post back if it isn't working as intended.
Posted: Wed Apr 01, 2026 8:34 am
by jem
Yes, it didn't charge let night so Im now sorted. Thanks all. Jem
Posted: Wed Apr 01, 2026 9:52 am
Perfect, hope it carries on the same.
Posted: Thu Apr 02, 2026 9:00 pm
by jem
But now I can set it to charge from the desktop . Any ideas? Error 44098
Posted: Thu Apr 02, 2026 9:05 pm
by jem
I have checked that mode scheduler is switched off (as on another forum it says that could be an issue). Thnaks
Posted: Fri Apr 03, 2026 9:27 am
by jem
I see this in scheduler (which I can not remove)
Posted: Fri Apr 03, 2026 9:31 am
by jem
Don't know why but its now accepted and times have been submitted, with the app working before so well I cant understand why this has been made so hard by "improving" the app. Thanks for all who have helped.
Posted: Wed Apr 22, 2026 10:21 am
by jem
I am still having problems with this.
I now want to switch off charging the batteries in off peak and can not find anywhere to do this in the app or the desktop version. Its such a complicated system and even though I have had batteries installed o=in my parents house I am nothing to set them up for off peak charging as its so hard to navigate. The preset "quick settings"i used previously to access charge times no longer shows what I need, i just see this. In the app I cant find any way of controlling batteries.
Quick seating screen shot attached.
