Page 1 of 2
EV Charger A series, C series L series which one is the latest?
Posted: Thu Mar 26, 2026 3:36 am
by Josh
Hi All,
Does anyone know which series EV charger is the latest/best?
I have a Fox ESS Battery and now need a charger and would like it in the same app (FoxCloud 2.0) so looking at Fox chargers.
Also does anyone have a list of Australian sellers as I can only find like 2 in the whole country.
Thanks in the bank!! :D
P.S we have had our Fox battery for almost 2 month as we are supper happy with it.
It never goes below 75% and the power company is always in the red. Bills < zero.
Re: EV Charger A series, C series L series which one is the latest?
Posted: Mon May 04, 2026 11:29 am
by MikeAshelford
Hey Josh, any update on this?
I've got the kh10 inverter and I'm thinking the a series is the go to, but I'm having trouble finding how it can connect.
Posted: Tue May 05, 2026 12:27 am
by Josh
Hi Mike,
I was told by a supplier here the 'L' Series is the newer one.
Beside the detachable cable option it has everything the 'A' series has.
One thing the 'L' has is the cables going to the power box can go straight into the back which the A can't
Nobody got back to me on here but maybe this will start a thread on it.
I've attached the data sheet for the 'L' and the 'A'
As for the inverter Mike, the chargers don't have any connection with them, it's own circuit it the switch board.
The way they interact is via the FoxCloud2.0 APP so you can set different triggers for stuff.
Anyway hope that helps
Posted: Sun May 10, 2026 9:42 am
by MikeAshelford
Thanks for that Josh.
Yeah it's a shame the info is so hard to come by.
I'm looking at an A series, but I'm slightly concerned that if the only comms is via the app and cloud, then it will react really slowly to PV linkage and changes in PV output etc.
Another thread I've got going says comms can go to the inverter. I'll try and find more info.
Posted: Tue May 12, 2026 9:59 am
by ginoposcolierogmailcom
Hi Josh et al - Following your progress with great interest because I also have a Fox battery (41.93kWh) & inverter (15kW)
There is also the C series EV charger which I understand has TWO EV charging ports - perfect for a 2 EV car household.
Posted: Thu May 14, 2026 1:09 am
by Josh
Hi Mike,
I could be wrong here but I think the PV stuff gets triggered directly from the meter (over rs485)
Is that what you mean, when there is extra solar being produced put it in the car?
I think the app is just for changing setting and displaying data.
Good point though if it has to wait for the app to update with its current situation then trigger a reaction.
Let me know what you find, id be very interested if there is a bottle neck I should be addressing.
Hi Gino, Yeah super happy with the big battery hey, mine hasn't been below 78% yet :D . Ok so that's what the C series is a duel charger, definitely would be the go if you had two car spots. I can't find any info on it here in Aust
My install is booked for two weeks away L series, I will let you guys know how it goes (Hopefully the car will arrive at the same time :roll: )
Posted: Thu May 14, 2026 5:14 am
awesome - how exciting a charger AND an EV :D Super keen to hear how it pans out. Yeh I've been cycling my 42kWh battery every day and achieving monthly credits through Flow Power
Posted: Mon May 18, 2026 1:11 am
by MikeAshelford
Hey Josh,
Yeah maybe if it gets triggered from the meter that'd be good! Just haven't seen that anywhere.
I guess i'll have to guinea pig it...
Let us know how the L series install goes. I'll be going the A series and installing a meter too. Fun and games.
Posted: Mon May 18, 2026 2:51 am
by MikeAshelford
Spoke to fox on the phone. They said the A seriec charger doesn't need to go though a smart meter.
Ev charger connects to ports 3 and 4 on the Kh inverter. A-A and B-B.
Will see how we go!
Posted: Mon May 18, 2026 3:11 am
by Josh
What you managed to get someone from Fox on the phone, it's a miracle!
That's cool, so to the inverter.
Did they happen to mention anything if you do have a smart meter?
I'm in the opposite boat to you, my smart meter is close to where the charger is getting installed and my kh inverter is on the other side of the house so running an extra cable will be a pain.
Have you got a date planned for your install?
Thanks mate
Posted: Sat May 23, 2026 5:32 am
by MikeAshelford
Hey Josh,
Sorry for the slow replies mate.
Yeah haha they answered straight away!! Was impressed.
If you have a smart meter, then I believe the wiring from the charger goes straight to the smart meter, and it handles both. There is a diagram in one of the pdfs that shows that.
Here is the link to the downloads that came in the a series box.
https://charging.foxesscloud.com/doc/#/ ... bbe536bf2b
I've got it on the wall and am running cables this week, so hopefully will have it working in a week or so!
In your case, did they run a cat6 cable? There may be spare wires running from your power box to your inverter that aren't being used, as the smart meter is probably only using 2.
Posted: Tue Jun 09, 2026 1:55 am
by ZonarHD
Glad I found this thread.
Ordered a single-phase A series charger for my upcoming EV. The documents posted have really helped and just have a couple of questions. Have a KH9.9 FoxESS inverter currently DC coupled with 6.6kw Solar & 23.3kw battery so am looking to take advantage of charging using excess solar etc.
1. Our place has a side-by-side carport & garage. The smart meter is in the carport and planning to install the EV charger on the inside of the garage. Will be on the other side of the wall to where the meter is. The garage and carport are separate to the house itself. Our KH9.9 inverter & existing switchboard is 20m away so it's practically impossible to run a cable neatly between the Inverter & EV Charger. Can the EV charger communicate with the Inverter through WiFi to take excess solar? Or can this be done via the Smart Meter with no direct connection to the inverter?
2. Have noticed on the installation instructions that it needs to be set up initially with the Foxswitch app needing an installer account. Our sparkie that we use won't have an installer account. I've ordered the charger through Revcharge. Will they provide an installer account to use, or should I attempt to set up one myself?
Posted: Thu Jun 25, 2026 3:03 am
by cpurn
hey guys, from melb here.
I have A series to KH10 and EQ4800L9. SIngle phase dc coupled.
My understanding is A series is newer than L series. A series lets you use swipe card to charge etc (I don't use this feature at home).
The green charge is always the hottest topic on Fox EV charger. I had a long journey to get green charge working, I was lucky enough to get some help directly from FoxESS Australia support and they came onsite to my place to investigate and fix.
For green charge to work, you will need rs485 from EV charger to the inverter - this is a must. This connections allows the ev charger to communicate with the inverter directly to assess the excess solar.
I haven't been able to really test this yet as it's winter here and I'm with globird zero hero plan (free 11am-2pm) and by the time zero hero ends, the sun is already pretty much on the low side.
Posted: Thu Jun 25, 2026 10:56 am
Hey wonderful feedback cpurn. As they days lengthen and green charge begins to kick in more often keep an eye out for the following
" The Fox ESS A-Series EV Charger requires a minimum of 6 amps to initiate and sustain charging.This means the charger needs roughly 1.4 kW of power (for single-phase setups) . If the charging current or the available excess solar dips below 6 amps, the charger will automatically pause."
Also, your charger may well be "V2G hardware ready". Can't wait for Fox ESS to activate the associated software.
Hope to hear from you
Kind Regards
Posted: Fri Jul 17, 2026 12:59 pm
by scorillo
Hey guys, I've just join in, so not sure if this topic is still active, but ..
I've got a three-phase P3 inverter, which if I understand correctly is part of the H3-Smart family Fox-ESS, + 18 kWh battery stack and a C-series EV Charger.
My experience so far, is that non of the C-series models support PV-Linkage (button greyed-out in FoxCloud 2.0 app), thus I can't tell my EV Charger "don't use anything from the grid, just use my PV production (and battery if available) to charge the car", which is a pity.
I really wish Fox-ESS would enable PV-Linkage for C-series too, in their future firmware updates.
Cheers!
[quote=ginoposcolierogmailcom post_id=16663 time=1778576380 user_id=4431]
[/quote]
Posted: Fri Jul 17, 2026 9:48 pm
Hi scorillo
U have a C-series!! Wow, I get the impression they're pretty hard to get in Australia.
Can you confirm you have two ports so that you can charge 2 EVs simultaneously.
I presume your charger is communicating with your H3 Smart inverter - is it doing so via Wifi or hard wired ethernet cable connection?
I'd prefer my EV charger to charge from PV and/or Grid but never home battery and yes I wish they'd pull their finger out with software/firmware upgrades :)
Also, I'm very keen to see at least the V2H (Vehicle to Home) if not the V2G bidirectional functionality activated. :(
Are you able to say where you purchased your charger from?
Thanks in advance
Posted: Sat Jul 18, 2026 4:20 pm
by scorillo
Hi mate,
I didn't have my 2nd EV delivered yet, so I can't confirm the simultaneous charging, but I'll come back to you as soon as I have it. (or when I get a friend over, we will definitely try with 2 EVs)
On the energy source, frankly we should be able to pick and choose, is not difficult to make that happen in the software, all the necessary info exists and the hardware supports this, but yeah, I'd go for PV -> battery (only until it gets down to 20%) -> grid (only, if I am not happy with % of the car battery charged for my next trip). I'm ok to use the grid for the remaining household usage.
The C-class V2G ready, but can't say I've seen that in practice yet. Not sure when we get to see it.
.. but the actual point that I will disappoint you with is this: I am located in Europe, and C series is available here. I have no clue about Australia.
Although, besides simultaneous charging (which is one reason for which I picked the C, while I overlooked the PV linkage by mistake), I don't see many other big advantage over L-series, at this point (with the current level of software features)
Stay tuned..
Posted: Sun Jul 19, 2026 6:34 am
Hi scorillo
What great feedback - especially the part about availability of the C series in Europe as opposed to Australia LOL.
Agree with all you've said - L series might be the sensible option for now especially if one only has single phase house supply &/or household's second EV is some way off etc .
Staying tuned :)
Many thanks
Sincerely
Posted: Sat Jul 25, 2026 6:29 am
by MikeAshelford
cpurn wrote: ↑Thu Jun 25, 2026 3:03 am hey guys, from melb here.
Been a while since I got the install.
Can't say I've had much success with Green Power or eco mode which is very frustrating. Yesterday it seemd to react but today eco mode just sat on 1.3kw and Green Power just keeps changing paused. Super annoying.
I'll find a sunny day during the week to call fox again and try and sort it out. Driving me a bit mad.
Posted: Sat Aug 22, 2026 1:13 pm
by vince088
I made an account specifically to reply to this thread, as I have been frustrated issues with my setup.
Just to be clear I am pleased with my Solar, Inverter and Home Battery system.
It is the FoxESS A series charger I am having issues with.
I have a FoxESS KH10 inverter with EQ4800 batteries and solar. I decided to stay with the same brand and purchased a FoxESS A Series EV charger. (All latests firmwares)
My installer did not install the communication cable between the charger and the inverter. Instead, he only used the CT clamps supplied with the charger, as he said this is how he normally installs all EV chargers.
Since then, I have experienced several issues:
1. Scheduling does not work correctly
The charger has its own app, FoxSwitch, but it can also be linked to the FoxCloud 2.0 app. When I create a charging schedule in FoxCloud, the schedule also appears in FoxSwitch, but the charging times shown are completely different. Both apps are set to the Melbourne/Sydney time zone.
Green Charging does not work (PV Link)
Green Charging does not work at all, even when my home batteries are fully charged and there is excess solar generation available.
Eco Mode is inconsistent (PV Link)
Eco Mode seems very hit and miss. The charger either does not charge at all, or charges at the minimum rate of 6A, approximately 1.5 kW.
At the moment, my only reliable option is to disable PV Link, and Charge with just the maximum charging speed to 32A, approximately 7.3 kW, and manually control the charging myself by turning the charger on and off when required. If I want to reduce the charging speed, I manually adjust the amperage in the app.
As a workaround for the scheduling issue, I have stopped using both FoxSwitch and FoxCloud for scheduling and now use my EV car's own scheduled charging function instead.
I am interested to know whether anyone else with a FoxESS inverter, battery and A Series charger has experienced similar issues, particularly where the communication cable between the inverter and charger has not been installed.
Posted: Sat Aug 22, 2026 9:43 pm
by MikeAshelford
I don't believe pv link will work at all without the data cable connection. It's not that hard to connect. Mind you it's still buggy and I'm freqi restarting the charger.
The schedule should work fine... Is pv link off and inverter and charger bound?
Posted: Sun Aug 23, 2026 6:34 am
by vince088
When you mention scheduler works, is that from the FoxCloud2.0 app or the Foxswitch app? because as mentioned when I set 1 schedule on the app, it syncs to the other app but the times are totally not in sync
Posted: Sun Aug 23, 2026 7:44 am
by MikeAshelford
I made the schedule in the fox switch app and it works nicely. But I just had a look at the schedule in the fox cloud app and you're right, the time is completely out!
Posted: Mon Aug 24, 2026 10:26 am
by vince088
FoxEss has finally replied to me, telling me to use the FoxSwitch app for Schedules to use with FoxESS A series charger.
Advised the 2 teams are working on fixing this timezone issue :roll:
Posted: Mon Aug 31, 2026 9:02 am
by carrot1401
Hope the C series (or any sort of Fox V2G charger) comes to the UK next year; looking at EV car but would want to use it to "run" my house as I regreat getting such a small 5kw battery!
Any got the C series? Thoughts?
