Page 1 of 3
Wrong usage data been sent to inverter. Problem solved. CT was incorrectly connected.
Posted: Tue Mar 24, 2026 3:21 pm
by VicByron
Invertor: H1-3.0_E-G2-WL
Battery: EP5
Our system was installed about 10 days ago, the battery did not charge from the beginning in SelfUse mode. Force charge works fine but the energy quickly is drained/exported to somewhere with 3.5kw/h till SoC min 10%. Last few days it was very sunny, the app indicated that all solar generated energy was going for Household use. For example, PV -1.6KW +Grid 360w = 1.960w to household and nothing goes to battery storage. However, our household at the same moment uses only 180 watts. We think that there may be an error in inverter settings. The installer has reported this to FOX to initiate a system diagnosis. So far, no changes. We hope you can help us understand the problem.
P.S. Where did the stored energy disappear? Twice used force charge for testing before afternoon but from 4 to 5 PM the stored energy rapidly disappeared somewhere before our eyes even though we were not doing anything at home (180watts). We assumed it got exported to grid. How can we stop this from happening again. We have not agreements about exporting energy.
Attached are few photos, screenshots:
1. Real use in house right this moment -+178watts but not exactly 1.59kw
2. Inverter Screen
3. Smart Meter Display
Re: Buttery does not charge. Wrong usage data indicated in app.
Posted: Tue Mar 24, 2026 6:14 pm
by MaterialBarracuda48
On your FoxCloud2.0 App, you can click on "Daily production" and it will show a power graph for the day.
Can you get a screenshot for yesterday and today please?
Posted: Tue Mar 24, 2026 7:04 pm
by VicByron
Of Couse, thanks. 23.03.2026 around 11:12 AM The Buttery charged up to 14% when switched off all fuses excluding main one.
Posted: Tue Mar 24, 2026 7:38 pm
I don't think your battery is charging much, as you don't have the best PV input, which you cannot control the weather.
And combined with your daily household power usage figures, you are draining it quicker than you are putting power in.
23rd
PV you made 6.70kWh
Load was 12kWh, so the battery would struggle to charge as there was not enough spare energy.
Do you know how big your solar array is?
Posted: Tue Mar 24, 2026 7:53 pm
by VicByron
During sunny days the solar panels show to generate between 1.4-1.9Kw whilst we used around 300-380 watt only (Router, laptop and fridge) which is why we fill confused and upset that the buttery does not charge.
For today we spend 9kw only over the hall day and 8.19kw yesterday. From Smart meter.
5 Solar panel 480watt each. We know exactly how much we use on a reglue day before we had the solar panels installed which is why it is easy for us to operate with the numbers.
Posted: Tue Mar 24, 2026 7:58 pm
by VicByron
Main questions:
1. The app shows wrong data.
2.Battery does not charge from Solar Panel.
3.Where does electricity disappear when the battery charged to 100% in Force Charge mode when all appliances at home are turned off?
Posted: Tue Mar 24, 2026 8:00 pm
VicByron wrote: ↑Tue Mar 24, 2026 7:53 pm During sunny days the solar panels show to generate between 1.4-1.9Kw whilst we used around 300-380 watt only (Router, laptop and fridge) which is why we fill confused and upset that the buttery does not charge.
Do you have a power graph for a good solar day?
Posted: Tue Mar 24, 2026 8:09 pm
by VicByron
There is.
Posted: Tue Mar 24, 2026 8:12 pm
VicByron wrote: ↑Tue Mar 24, 2026 8:09 pmThere is.
I do not see any solar generation, PV Production show 0.00kWh
Posted: Tue Mar 24, 2026 8:14 pm
by VicByron
What I am tolking about. :)
Posted: Tue Mar 24, 2026 8:15 pm
by VicByron
One more
Posted: Tue Mar 24, 2026 8:18 pm
by VicByron
In the last photo: What PV producing at 13:30 exactly
Posted: Tue Mar 24, 2026 8:19 pm
VicByron wrote: ↑Tue Mar 24, 2026 8:14 pm What I am tolking about. :)
A graph for 21st would be best to show.
Posted: Tue Mar 24, 2026 8:26 pm
by VicByron
21.03.2026 We used Force Charge mode for testing, the battery charged up to full in about 2 hours and then suddenly leaked to nowhere, this for certain because right that moment we were using about 280watt. I was watching the leak happening life on screen 3.5Kw/H. As you can see until 11 AM the battery was not charging in Self Use mode.
Posted: Tue Mar 24, 2026 8:32 pm
by VicByron
In force Charge mode we switched OFF charging from grid that is why the battery was charging from Solar Panels only.
Posted: Tue Mar 24, 2026 8:34 pm
I do not know where it went, but it was a load in your home.
Oven
Hob
Water heater
These would be the most likely candidates.
Posted: Tue Mar 24, 2026 8:42 pm
by VicByron
We are absolutely sure that no appliances were running at this time. This is the quietest time in the house. This is why we are confused. The first thing we thought was that settings permit certain amount of energy going to grid, being exported. Why we are saying that wrong data show in app.
Posted: Tue Mar 24, 2026 8:47 pm
I don't see any red colour export lines below the 0kW line. So the power was used inside your home somewhere, I do not know where it went.
You are going to have to investigate your home circuits, one by one until you find your drain.
Posted: Tue Mar 24, 2026 8:48 pm
by VicByron
For example, right now:
490 watt,
PC, Light - 1 Bulb, monitor, heating.
Posted: Tue Mar 24, 2026 8:54 pm
by VicByron
This good idea! We can't even imagen where all the PV and Battery energy could go when everything was off. We will try to turn off all the switches in the fuse box except for the main. Thanks.
Posted: Tue Mar 24, 2026 8:58 pm
In this picture you posted, you can see the purple PV power curve that increases and then comes down towards end of day. It looks like a rainbow shape.
Now what IS weird is your power usage below the 0kW line, is a mirror.
So the more you make solar, the more power your home uses!
I have to ask, do you have some power diversion device to heat hot water, or an EV charger that operates when it thinks it has excess electric?
Posted: Tue Mar 24, 2026 9:00 pm
by VicByron
It seems that the electric leaks happens only when it transfers to household because when we use electric from grid - no leaks happen.
Posted: Tue Mar 24, 2026 9:03 pm
by VicByron
Heat pump uses max 1.5Kw at full capacity. But at this time the heat pump was off. No EV charge. ;) This Smart meter right now. This mx for the next 30 min then it drops to 340watt
Posted: Tue Mar 24, 2026 9:09 pm
If you look back to your picture from the 21st, you have selected 08:36 as a "point in time"
Now if you go back here, and this time move finger from 09:00 to 12:00, you will see as your PV increase in value, so do your load will keep increasing in a matching pattern.
Example: If your PV was 1kW, your load will be very close to 1kW. If your PV is 2kW, then your load becomes 2kW.
With some investigation in your home, you will find what is taking this "spare" power taking it away before your battery can charge up.
Posted: Tue Mar 24, 2026 9:11 pm
VicByron wrote: ↑Tue Mar 24, 2026 9:03 pm Heat pump uses max 1.5Kw at full capacity. But at this time the heat pump was off. No EV charge. ;) This Smart meter right now. This mx for the next 30 min then it drops to 340watt
What does your FoxCloud2.0 App show for the same time as the smart meter time?
