Force charging settings
Posted: Mon Mar 16, 2026 11:19 am
by Mhys1016
Hi all.
I can't seem to find the section on the app where I can see and also edit my force charging times .
I'm sure this was under battery settings but can't find it now.
Did something change when the app got its face lift ?
Josh
Re: Force charging settings
Posted: Mon Mar 16, 2026 11:30 am
by MaterialBarracuda48
Will has a video, it was moved about.
Alternatively, login with your credentials here
Go to the Quick Settings top right, and you can find the basic battery charge function there
Posted: Mon Mar 16, 2026 11:56 am
by Mhys1016
Thanks for the reply but when I go into work mode card there is no info or button for Forced charge as shown in the attached yt video . Infact there is no Forced charge or Forced discharge button on my app. Any ideas ?
In the meantime I have found the info needed on the desktop version thank you..
Posted: Mon Mar 16, 2026 12:09 pm
It was pulled from the App a few versions back, now the website is the way for the basic charging.
Best of luck with it again.
Posted: Mon Mar 16, 2026 12:17 pm
by Mhys1016
Oh right. That will explain why I can't find it. Thanks for your help.
Josh
Posted: Mon Mar 16, 2026 12:19 pm
Mhys1016 wrote: ↑Mon Mar 16, 2026 12:17 pm Oh right. That will explain why I can't find it. Thanks for your help.
Josh
A pleasure Josh
