Battery charged to 100% and is now not working in self usage mode
Posted: Mon Mar 02, 2026 4:25 pm
by nigeldent07
Hi all,
I had my Fox ESS battery installed by Octopus Energy just over 3 weeks ago and the battery has been working quite happily in self usage mode. (I am in Cambridge, UK - not sure where this forum is based)
When checking the status of the battery at lunchtime today it had charged from around 8.30am right upto 100% full. The battery has now sat at 100% SOC all day rather than providing power to my home. This is the first time it has done this in 3 weeks and has cost me around £14!
The only thing that changed last night was I plugged my EV in for the first time and charged from 11.30pm to 05.30am.
I have now set up a schedule for the battery to charge from grid overnight from 11.30pm to 05.30am as I am on Octopus Intelligent go tariff.
When I am working from home alone can I set the battery to export to the grid for the 15p export rate?
When I spoke to Fox service via Whatsapp they said that the battery is working normally and the reason it fully charged is because of the solar PV. BUT I only have a 2.7kW system and the rest of the charge came from the grid on an expensive tariff.
Could someone please help me as I want to make sure my battery system is set up properly for my home?
Re: Battery charged to 100% and is now not working in self usage mode
Posted: Mon Mar 02, 2026 6:05 pm
by MaterialBarracuda48
nigeldent07 wrote: ↑Mon Mar 02, 2026 4:25 pm This is the first time it has done this in 3 weeks and has cost me around £14!
That £14 at the peak rate (est 32p) would be almost 44kWh of power from the grid on peak pricing.
I assume you might be new to IOG, if yes, you need to wait 1-2 days for Octopus to recalculate and the £14 will drop down drastically. It does this all the time, so you will learn to ignore it, and check later or your bills.
Posted: Mon Mar 02, 2026 6:20 pm
If you look at this first picture, you will see Sunday used less power than Monday
If you now look at the estimate costs, Sunday looks much higher.
If I wait for Tuesday or Wednesday, this will recalculate and Sunday cost will drop.
