FoxESS Home Battery won't charge more than 364W.
Posted: Thu Feb 26, 2026 11:19 am
by FoxyESSHomeUser
Hi all,
Has anyone come across this?
But no matter what I tell the battery to force charge or Min SOC at 100% it will never charge more than 364W. When I did get it installed there was no issues with charging at the full 1,100W rate. Nothing has change at home, its in the same socket, same space.
I've removed it from my energy provider portal and re-added it, also the P1 Meter. Even tried different Wifi settings, but no matter it won't charge more than 353-364W.
Thanks for reading.
Re: FoxESS Home Battery won't charge more than 364W.
Posted: Thu Feb 26, 2026 5:17 pm
Can you tell us which inverter model and which batteries you have please, also what method are you using to charge the batteries - if it is scheduler (what settings were used please) or was it the older Grid Charge periods.
A couple of things to check, if you go to the inverter and go into Settings (password 0,0,0,0), then on-grid, then Export Control, there will either be 1 or 2 options for ImportLimitPwr and ImportLimitCur
These should be set to at a minimum the maximum size of the inverter i.e. an H1-6.0 the ImportLimitPwr should be set to 6000 watts and the ImportLimitCur should be set to 30A - can you look to see what they are now and post back the values.
There is also a setting within the Inverter Settings, under Battery, MaxChgCur - this should be set to 40A as default, again post back what you find there now.
Posted: Thu Feb 26, 2026 6:19 pm
by foxessybatteryuser
Hi Team,
Seems it was 8 characters and not 4:
Posted: Thu Feb 26, 2026 6:22 pm
Actually,
0,0,0,0 Does not work, seems to just disconnect.
Posted: Thu Feb 26, 2026 9:20 pm
by evilbunny
The default is 12345678 but getting in doesn't get you anywhere.
Posted: Thu Feb 26, 2026 9:27 pm
evilbunny wrote: ↑Thu Feb 26, 2026 9:20 pm The default is 12345678 but getting in doesn't get you anywhere.
Yup, same error "check network and reconnect".
Like somehow the system thinks that I want to login, enter the password and just as I press enter I disconnect my network... :evil:
So im not able to login and get the details of ImportLimitPwr and ImportLimitCur.
Weird that I don't see any of these values when I have it connected to HomeAssistant.
Is there any other way to get the values, like via the https://www.foxesscloud.com/ or something?
Posted: Thu Feb 26, 2026 9:35 pm
by evilbunny
foxessybatteryuser wrote: ↑Thu Feb 26, 2026 9:27 pm Yup, same error "check network and reconnect".
I had an easier time when first logging in by connecting to the data logger using it's built-in AP with WiFi password mtmt2020
