New (Broken) behaviour of force charge? Solar is exported once FCSOC is reached.
Posted: Sat Feb 21, 2026 9:41 am
by stevo125
Previously when setting force charge to say 30%, battery would charge to 30% from grid, but battery would continue to charge beyond 30% from any excess solar (Self use)
The % you set in Force-charge now seems to be setting max-SoC, rather than a FCSOC so any surplus solar is now exported (Feed-in priority)
I'm struggling to fathom under what circumstances that behaviour is desirable. Is this another bug in the update?
Its similar to the other weird behaviour with force discharge acting as a min-SOC rather than a FDSOC.
H1-G2 1.51 / 1.04 / 1.69
EP5 1.011
In attached image FCSoC is 11%
Re: New (Broken) behaviour of force charge? Solar is exported once FCSOC is reached.
Posted: Sat Feb 21, 2026 12:14 pm
Fox have been made aware of this and i’m hopeful that the behaviour will be changed back or add an option to use it the way most people want to
Posted: Sat Feb 21, 2026 12:19 pm
by stevo125
Dave Foster wrote: ↑Sat Feb 21, 2026 12:14 pm Fox have been made aware of this and i’m hopeful that the behaviour will be changed back or add an option to use it the way most people want to
Hi Dave.
Thanks for replying.
So to confirm, are you saying fox are aware of both the force charge and force discharge behavior being "undesirable", but not (yet) any commitment from them to fix (revert to old behaviour)??
Posted: Sat Feb 21, 2026 2:44 pm
stevo125 wrote: ↑Sat Feb 21, 2026 12:19 pm
Hi Dave.
I can only go from what I know, and that is they have been collecting feedback about the issues with the new app scheduler, I don't know when they will respond but I hope it's soon, you can still set the desired effect if you use the website or Energy Stats.
Posted: Sat Feb 21, 2026 2:47 pm
by stevo125
Can you advise on how to go about that please.
I tried with cloud v1 and energy stats and couldn't figure out a way to get it working the way I wanted. I thought maybe the (bat) scheduler entries might have been the key, but no dice.
Posted: Sat Feb 21, 2026 4:06 pm
On Energy Stats if you go to Settings, and choose Inverter near the top - you can manage schedules, a schedule there looks very much the same as you will be familiar with where you can set minsoc, maxsoc, FCsoc, FCPwr but when you set them here they don’t get overridden by the default 10% and 100%.
It’s better to set FCSoC and maxSoc the same value (say 30%), the maxSoC here is the ‘grid maximum soc’ it will stop the grid charge here but continue to charge past with solar.
Likewise if you set a schedule in the Fox V2 app and then go to the V2 website https://www.foxesscloud.com/v2/login, click on the purple box ‘Quick Settings’ top right corner you’ll be able to go into Mode Scheduler and overwrite the incorrect settings the app has made (i.e. you’ll see that minSoC will be 10%, and maxsoc and FCsoc will be 100% - change them to your desired value and ‘confirm’). Don’t edit them in the app or they will be overwritten again.
Posted: Sat Feb 21, 2026 4:27 pm
by stevo125
I'm not following how this helps. What am I missing?
In the force charge case, I set in the app:
FCSoC =30
And web then shows
FCSoC =30
MaxSOC=100
Expected behavior is grid charge to 30%, then any excess solar would be sent to the battery up to 100%. But instead as soon as 30% is reached, solar is exported. To me its behaving as if its setting FCSOC and maxSoC to the same value (30) but that doesn't seem to be the case.
Posted: Tue Feb 24, 2026 1:17 pm
by stevo125
I've logged a ticket with Fox. Not expecting much, but will share here for anyone else searching.
Hello.
I've noticed an incorrect change in behaviour on recent firmware for force charge and force discharge modes.
Force charge issue:
Current behaviour: FCSOC value is applied to grid charging and solar charging. When battery SoC = FCSOC, PV power is exported rather than directed to battery.
Expected behaviour: FCSOC applies to grid charge only. Solar power is directed to battery charging till MaxSOC is reached.
Force discharge issue:
Current behaviour: FDSOC value is applied to grid export and and house load. When battery SoC is reaches FDSOC, house load is supplied from grid.
Expected behaviour: FDSOC value is applied to grid export only. Once battery SoC is reaches FDSOC, battery continues to provide home load till MinSoC is reached.
It essentially appears that Minsoc/maxsoc are completely ignored in Forcecharge and forcedischarge modes.
Can you please advise if Fox are aware of these issues, and when a fix is expected. Thank you
Posted: Thu Feb 26, 2026 4:15 pm
by CDubbs
Just posted on another thread, for last 2 days my system has worked the way most of us want it to, ie, FD to set FDSOC, then fall back to battery to MINSOC before drawing from the grid.
I had not bothered to FD for a month due to the mess around switching off the schedule to get it back to self use.
2 days of full battery and was surprised when it hit FDSCOC to see it revert to self use and not grid supply.
There has been no changes to my firmware since I first raised this with Fox in January.
viewtopic.php?p=12544#p12544
viewtopic.php?p=13611#p13611
Posted: Fri Feb 27, 2026 9:35 pm
by CDubbs
I’ve now noticed a pattern each day after FD.
The system now discharges to set FDSOC, then draws from grid for approx 10mins before falling back to self use on the battery.
The image shows this behaviour as logged on the myenergi app and the Fox app, it’s just clearer on the myenergi app.
It’s happened 4 nights running when the battery has hit the set FDSOC of 30%.
So there’s some work for Fox to do to get the system running as it should be.
Posted: Mon Mar 02, 2026 12:43 pm
by alexls
I got a response from Fox on 26th Feb:
We sincerely apologise for any inconvenience and appreciate your patience.
Our current system logic is indeed designed so that once the FD SOC is reached, the battery stops discharging during the Force Discharge period (especially if the time block is relatively long).
Thank you very much for your feedback. Our project team is actively working to optimise the platform, so that after reaching FD SOC, the system can automatically return to Self-Use mode, maximising self-consumption and overall efficiency.
We truly appreciate your suggestions and will strive to make this feature available as soon as possible.
Posted: Mon Mar 02, 2026 12:47 pm
by CDubbs
Yep, same response I got on 23 Jan
I have raised a new ticket today showing that they have modified the logic, but there is a delay of 10 mins after FDSOC is reached where the system now goes to grid supply before the system reverts to battery if there is any capacity before MINSOC is reached.
Posted: Wed Mar 18, 2026 12:18 pm
by CDubbs
Fox have responded to my ticket and have stated they are working to release a fw update end of March to resolve the issue .
Posted: Wed Mar 18, 2026 12:23 pm
by MaterialBarracuda48
CDubbs wrote: ↑Wed Mar 18, 2026 12:18 pm Fox have responded to my ticket and have stated they are working to release a fw update end of March to resolve the issue .
Cheers for the update, good to know they are cooking a fix up.
Posted: Sat Apr 04, 2026 9:06 am
by DavidJW
H1-G2 Master 1.53 and Manager 1.70 are now available in the FoxCloud 2.0 app. I am not brave enough to try them yet, as the release notes are not posted, there is no feedback on this forum, and I can only roll back by contacting Fox ESS Tech Support.
Posted: Sat Apr 04, 2026 9:50 am
by CDubbs
Exactly my thoughts, updates available since 23/3 but no release notes, and no one appears to have stuck their head above the parapet 🤣
Waiting for a Guinea pig to come along.
It appears the WW dongle upgrade might have been pulled, as it’s listed under Wills spreadsheet as problematic, it appeared on my app for an upgrade for 24 hours and has now disappeared.
Fox need to up their game on release testing before pushing out to the masses. Basic school boy errors that got people sacked in my industry.
Posted: Sun Apr 05, 2026 11:58 am
by alexls
https://fox-ess.tech/firmware-release-notes/
Please note that there may be a short delay (typically several days) between firmware becoming available via the cloud and the corresponding update appearing in these release notes, due to validation, documentation, and publishing processes.
This doesn't really make much sense, if you ask me. By the time you've tested, validated, and published the firmware itself, surely you can have proof-read the release notes...
Posted: Sun Apr 05, 2026 4:34 pm
by DavidJW
My FoxCloud app now says Master 1.51 and Manager 1.69 (the versions I have been on for several months) are the latest versions. It looks like the update has been pulled, at least for end-user installation.
Posted: Sun Apr 19, 2026 11:16 am
by alexls
Updates (Master 1.51->1.53, and Manager 1.69-1.70) are back in the app. Waiting for release notes and/or other people to try them first though.
Posted: Sun Apr 19, 2026 2:55 pm
by CDubbs
Since Fox unilaterally downgraded my Master to something that was pants, it’s now a weekish since my installer downloaded 1.53,1.04,1.70
So far perfect, everything works again as it should.
No issues with forced charge, mode scheduler, etc etc
The only sequence not tried is FD as no need at present export levels
Posted: Sun Apr 19, 2026 11:55 pm
by CDubbs
Update to above
Run a FD and when the session finished the system returned to self use and no grid input
So appears all good on this fw
Posted: Tue Apr 21, 2026 6:17 pm
by NickJH
This is not a fix for me. Once the FDSoC is reached (95% in this case), Solar switched to charging the battery, but the Home was supported by Grid Import, so no improvement, See the image:
