Currency symbol incorrect
Posted: Tue Feb 17, 2026 10:21 am
by pembera
I'm a few days in with FoxCloud, so apologies if this has come up before (could't see anything via search).
Despite setting the currency to GBP during install, and all the settings (address, region and currency) being apparently correct, the tariff and revenue figures are displayed with the Euro symbol in both the phone app and web app and not £. I've searched and can't find any additional currency settings to change.
I'm obviously missing something - any tips?
Thanks!
Re: Currency symbol incorrect
Posted: Tue Feb 17, 2026 10:36 am
by retsplines
In the mobile app, it's top-right menu, Edit Home, Currency.
In FoxCloud 2 it's "Edit Plant" (top right pane on the dashboard) -> Currency.
I found that in the latest rework of the app the £ symbol has changed to "p" anyway so even set to GBP it's not correct.
Posted: Tue Feb 17, 2026 10:39 am
by MaterialBarracuda48
In the FoxCloud2.0 App, if you press the 3x dot menu ... top right, and edit home, currency is 2nd entry, see if it is set to Euros, and change to GBP and make sure to scroll down to save at the bottom.
I just tested on phone and was able to swap back and forth with no problems.
EDIT: I see retsplines posted the same advice.
Posted: Tue Feb 17, 2026 10:42 am
retsplines wrote: ↑Tue Feb 17, 2026 10:36 am I found that in the latest rework of the app the £ symbol has changed to "p" anyway so even set to GBP it's not correct.
Interesting, mine does show the correct £
Another bug to chuck on the pile :D
Posted: Tue Feb 17, 2026 11:58 am
by evilbunny
I couldn't get the $ symbol until I went into the tariff section, just setting the default currency does nothing as best I can tell.
Click on "Me" at the bottom right of screen, then "System Settings", then "Tariff", then click on the tariff you want to set the currency for, then in the top right of screen there is a sort of edit icon, then click on "Currency" etc...
Posted: Tue Feb 17, 2026 5:05 pm
by pembera
Thanks everyone.
I've checked in all the places you pointed out and it was already set correctly (i.e. to GBP).
Have experimented and changed the currency to USD (and saved) on phone and web, just to see what happens, and the revenue figure in both the phone app (2.0) and the web app still shows the Euro symbol!
Think there is something subtle going on...I'll keep trying.
Thanks again
Posted: Tue Feb 17, 2026 5:08 pm
by pembera
Scratch that - sorted!
Thanks evilbunny, your method worked!
Cheers all, can relax now!
Posted: Tue Feb 17, 2026 11:30 pm
by evilbunny
pembera wrote: ↑Tue Feb 17, 2026 5:08 pm Scratch that - sorted!
Yea constantly seeing the Euro symbol irked me too until I accidentally came across the currency setting in the tariff section.
Having the setting in the tariff section does make sense, although I can only think of multinationals that would want multiple currencies on multiple systems.
I haven't tested but I assume any tariffs added after setting the default currency will be set to that currency.
The app really should ask for a default currency on setup rather than just defaulting to the Euro. Alternatively prompting for a currency when adding a new tariff would be ok too.
Posted: Wed Feb 18, 2026 7:19 am
by pembera
Yup!
Posted: Thu Feb 26, 2026 12:18 am
by evilbunny
Looks like it was a user error on my part and when adding a new tariff there is a currency setting but it doesn't default to the home default, instead choosing the Euro.
Our power plan switched today so I deleted the old tariffs and then when I added the new tariffs I noticed above the "Manual" and "Smart" options the currency option as well, don't know why I didn't notice it before.
So the app does actually ask for the currency in the right spot, but the app doesn't use the home default as the currency default for the tariffs.
I have no idea why they even have a currency setting in the home settings as it doesn't seem to do anything but confuse people.
