New install or addition to existing - UK
Posted: Tue Feb 10, 2026 5:37 pm
by Sjc123456789
Hi Guys and Gals, apologies if this is in the wrong section as I already have a system but I'm looking for advice to add to existing or put a new section in. let me explain.
I've 25 x 445 Astronergy (11kw) on my garage roof, south (SSW) facing but shallow angle 5 degrees.
We've 2 H1-5.0-E-G2 2 x 5kw inverter in parallel (I think, I'm not massively technical), so 10kw
16.6kw of batteries, 2 Masters and 2 Slaves at 4.15kw each (ECM/ECS4300).
We've a couple of ohme chargers and 2 and 1/2 electric cars (smart fortwo eq).
We have an export license for 8kw to the grid and use octopus at the moment.
We've just had the gas disconnected and intend using the solar and batteries for the heating, cooling and hot water.
We're just having some SYO (see you out) projects done on the house, rewired, underfloor heating, heat pump, air con and changing the profile of the roof plus a small extension.
This will give me the option of having another 14 solar panels on the new bit of roof, plus possibly and other 12 on the old bit. I'm thinking just the new bit for now, so another 6kw. The roof is SSW facing at 15 degrees.
I understand in the peak of the summer we'll have 17kw of solar, on the existing system we did have a little bit of clipping, from 11kw to 10kw, but not enough to worry about. We didn't put anything to the cars, we just exported after the batteries were full. For many months we used what was in the batteries through the day, supplemented with the solar - we had a gas boiler though for CH and hot water.
I'm thinking our electrical demand will be a lot higher, both summer and winter. The heat pump will be a 10kw output one, and were thinking of either a 5 or 7kw aircon (just 3 rooms). I'm expecting the surplus solar in the summer will go into making the home office a lot more comfortable through the day and a couple of the bedrooms on an evening.
Thats the thinking at the moment - very happy to hear other ideas.
thanks in anticipation, Simon,
Re: New install or addition to existing - UK
Posted: Tue Feb 10, 2026 7:23 pm
by MaterialBarracuda48
If you are looking long term, and many panels... might be worth looking into the cost of 3-phase upgrade (though this could be silly money)
Just also note that the 10kW heat pump and the 7kW of AC usually refers to the HEAT/Cooling output usually, so you might find the real power use is much lower. Hopefully you are already aware of this.
If your needs do increase heavily, it might be worth looking into increasing battery capacity, but some ToU tariffs like Octopus Cosy, could be used for Winter time to keep the heat pump costs down. It can be worth doing your sums to check what tariff works depending on time of the year.
Home Assistant could be a good shout if you don't have some automation setup, as this could be used to better control how your systems work and interact with each other.
Posted: Wed Feb 11, 2026 6:54 pm
Just a few initial thoughts, you’ve got 2 H1 5kw’s in parallel which gives you 4 strings and they are currently maxed out.
If you add another H1 5kw inverter and parallel to match existing inverters you won’t have the string capacity to add the 14 +12 panels, I guess you could add 2 H1’s and parallel them all together but there will be a lot of system losses and small battery stacks.
I’d suggest replacing your 2 H1’s with a KH10.5, slightly more capacity and still has 4 MPPT’s for your existing strings, and then add another KH10.5 for your new strings probably over 3 or 4 of it’s MPPT’s then have a battery stack on each.
2 larger inverters running in parallel will give you more MPPT’s to handle everything you are planning and still be within their performance specs and whilst the export limit may only be 8kW they will be able to supply upto 21kW internally if your batteries are capable of supplying that.
I agree with what @MB said, you are definitely going to need more battery capacity with only an 8kW export limit you need somewhere to store the extra energy so you don’t end up derating the MPPT’s at peak solar.
The problem with 2 smaller ECS4300 stacks is their max power output, they have a maximum ‘peak’ discharge current of 50A (and a recommended discharge current of 35A) but with a nominal voltage of just 115.2V each battery stack is only able to provide 4kW continuous or 5.7kW peak (so 2 stacks is 8kW max continuous output).
If you go with larger inverters having more slaves in each stack will increase the power they can supply for all your house loads, for example an extra 2 slaves in each stack would double your battery capacity and give you a combined power output of 16kW. Even if you just add 1 slave to each stack you’ll still increase your maximum combined continuous power to 12kW - so for my money add as many extra slaves as you can justify, that’s the way to go.
