Hi all! Looking for some help as to how I can maximise my new system. Any help would be greatly appreciated.
I recently had a 13.3kw solar system installed with a 10kw fox ess smart inverter and a 48kw fox ess battery.
When my battery reaches 97 - 98%, my solar panels will stop sending power to the inverter and the battery will start to discharge at a trickle rate. If I was to turn my air-conditioning on, the panels will start sending enough juice to the inverter to cover the load being drawn without it being taken from the battery.
What I would like is for once my battery reaches 97 - 98%, for my solar panels to keep sending power to my inverter and then sell it back to the grid.
Is there a way to do this?
I bet your export limit is set to 0 watts or you've got your system in force charge mode instead of self use.
I've checked the settings as per your video and the export limit is already set to 13000w. When i check my app, it comes up as self-use. Let me know if you need photos
