Feed In Priority
Posted: Sat Jan 24, 2026 10:41 am
by Sysiphus
Why am I getting an error code: "44096-Unsupported function code" when I try to enable Feed In Priority?
Inverter: H1-5.0-E-G2-WL Version_Master:1.51 Version_Slave:1.04 Version_ARM:1.35
Battery: EP12 Version_BMS:1.011
Or am I getting a bit ahead of myself in trying to enable this function?
Best regards,
Derrick
Re: Feed In Priority
Posted: Sat Jan 24, 2026 11:07 am
by MaterialBarracuda48
You probably have a schedule setup, or grid charge enabled.
Turn off these and try the change.
Posted: Sat Jan 24, 2026 12:54 pm
Yes the 44096 error is an unfriendly way of saying that the scheduler is enabled and that stops you making workmode and soc changes - disable scheduler to change the workmode.
Posted: Sun Jan 25, 2026 9:06 am
by Sysiphus
Many thanks for the helpful replies.
Is there any possibility that someone, in a position to do so, might feed back to Fox that a friendly and informative message might help to reduce the tendency to panic?
Best regards,
Derrick.
Posted: Sun Jan 25, 2026 10:35 am
Post a message here Derrick,
Feature Requests
viewforum.php?f=51
Will has some contacts at Fox, and I think one of the Fox UK team visits the site.
It would actually reduce panic/tickets being made if they just wrote up some better error messages.
Error 44096:
"Please check that you do not have a schedule enabled at this time"
