Generation FIT readings and Forced Discharge
Posted: Thu Jan 22, 2026 11:31 am
I added a FOX ESS battery to my solar installation about two years ago and last November, I switched to Octopus Flux to use the battery to take advantage of the cheaper rates at night. I did this by using the mode scheduler with forced charge at night and forced discharge between 16 00 and 19 00. I have noticed that my Generation FIT reading meter has shot up. The generation statistic from the battery which the meter reads has a much higher value than the PV produced KWH. I had assumed that the Generation FIT readings (as opposed to the export FIT readings) were for the PV generated power not the KWH that passes through the inverter. Has anyone else encountered this? I am worried that the Generation FIT Meter may have been incorrectly setup. Any help gratefully received.
