CT Clamp or Smart Meter (DDSU666)
Posted: Tue Jan 20, 2026 6:30 am
by ColinR
I am getting KH10, EQ4800-L9 and panels installed. It will all be DC coupled. My question is about whether the supplied CT Clamp (provided with KH10), is 100% compatible with all the CloudVersion2 functions as well as all the AMBER Smart Shift functionality (including solar curtailment function). Or should I get a Smart Meter like DDSU666 or use the existing Fronious Smart Meter (I have existing Fronious kit which is being removed). I guess what I am asking is whether to go standard CT Clamp or Smart Meter like DDSU666 (or use existing Fronious Smart Meter). What are the thoughts out there?
Re: CT Clamp or Smart Meter (DDSU666)
Posted: Tue Jan 20, 2026 8:56 am
It makes no difference to the functions of the inverter, there are pro’s and cons for both - the CT comes with the KH as standard it’s accuracy is usually within 2% (a meter is a bit better).
Main difference is cabling distances a CT cable should really be kept short ~ 10 metres (max 20m but accuracy will fall), a meter can be cabled over large distances without loss of accuracy or function.
If you have no distance constraints, go with the CT.
