New AC coupled Battery - live load accurate, cumulative load incorrect
Posted: Thu Jan 08, 2026 12:25 pm
I've just retrofitted a new Fox ESS battery, with 3 phase inverter AC coupled to my current PV solar array and Sungrow inverter.
Generally all is work fine in reality.
Real-time live power data is accurate (with regards to magnitude, not sure about direction of power).
My problem is with the cumulative Load value when I look at the day by day data. It's represented as Load(-) and I understand this means that I have a 3rd party PV solar array producing abundant energy (which I do).
It just seems that the Load(-) is calculated by = Grid(export) + battery charge - battery discharge. There's no other variable there.
Live data displays Meter2 curve accurately (but is in the 'usage' area under the horizontal line).
Installer came and out and is happy with all the CT clamp placements (he mentioned I have 6 as I have 3 phase).
I attached screenshots. Any ideas? Is this just an app data read issue because my system is AC coupled?
