Considering 4 Fox ESS EP12 batteries - Can you stack two batteries in front of each other?
Posted: Sat Jan 03, 2026 9:52 pm
by sw1000
First post, I'm considering a 4 Fox ESS EP12 11 KW/h Batteries , I have a total of 230cm of wall space which won't be enough as each battery is 70cm plus 30cm between them.
What I'm think is can I have two lots of two batteries i.e. one battery and then another one in front of it, I cannot see any issues with this in the install guide with regards to ventilation, this would provide the ventilation at the sides and above as per the 30 cm requirement.
Each unit is 18.5cm deep so 37 in total , maybe leave a 10cm gap between the front and back battery.
Re: Considering 4 Fox ESS EP12 batteries - Can you stack two batteries in front of each other?
Posted: Sun Jan 04, 2026 2:13 pm
The batteries can be floor mounted but should always be held against a wall as an anti-topple measure, at over 100kg each, they would make a mess if they fell over that’s why Fox wouldn’t approve of them being mounted in front of each other, even with an air-gap.
Perhaps there is something you can do to build a brace that would allow the forward battery to be braced to the wall or battery behind.
Posted: Sun Jan 04, 2026 3:22 pm
by sw1000
Thanks Dave,
Appreciate the response, maybe have to consider a different option, maybe a Fox stack or maybe 3 batteries only
Posted: Wed Jan 07, 2026 11:36 am
by WyndStryke
If you want high capacity, then CQ6 modules give the highest capacity per stack, and is heated & has a reasonable IP rating (so should be OK for outside).
The EQ4800 matches the capacity of 4x EP11 modules, but doesn't have a heater so isn't suitable for cold locations.
I'm not sure about the other EQxxxx batteries as far as a heater goes, but none of them match the EQ4800 or CQ6 in terms of capacity.
Posted: Sun Feb 08, 2026 9:53 pm
by abc1
Is cq6 available in UK and Ireland?
Posted: Sun Feb 08, 2026 9:57 pm
by WyndStryke
No idea, the CQ6 and CQ7 are on the UK website, but I don't know if distributors will have them.
Posted: Fri Feb 20, 2026 3:27 pm
by Antlen
We are having 2 of those batteries installed in March and our installer says that you can.
