Limited battery info in app
Posted: Sat Jan 03, 2026 10:10 am
by Pagglukia
Thanks in anticipation for your help…
I have a EP5 battery which has been installed for 18months and working faultlessly, however the app only shows limited information:
Firmware version 1.003
Any thoughts please?
Re: Limited battery info in app
Posted: Sat Jan 03, 2026 10:17 am
by MaterialBarracuda48
I think you have half-answered your own question, your firmware is 1.003 and current is 1.011.
Contact your installer or email Fox Support directly (with your issue/request and serial number for Inverter given)
Posted: Sat Jan 03, 2026 10:19 am
by Pagglukia
Thanks, I wondered if this was the case.
Will I notice any other significant changes with the updated firmware?
Posted: Sat Jan 03, 2026 10:21 am
I suspect you won't get much in the way of obvious changes other than values might now be picked up in the app.
You might also wish to upgrade your actual Inverter at the same time.
Find support email/phone if you wish here
https://www.fox-ess.com/contact-us
If you email, make sure to check SPAM folder regularly as their reply might land there.
Posted: Sat Jan 03, 2026 10:22 am
by Pagglukia
Thanks, will do
Posted: Sat Jan 03, 2026 10:27 am
Here is what it could look like after upgrade
Best of luck with your update
