That sounds like what I was planning.
Where have you ordered from and how much if you don't mind me asking.
yep, that is spot on what I do when upgrading customers batteries. Cubes just make it easier as you don't have to mess around with brackets and cables. Please post pictures once done or get someone to record you upgrading it so we can create an upgrade video to help others.
Did you get the upgrade done yet? I am getting my extra cube slave batter day after tomorrow, Do i need to remove any screws before i lift the master and place the new slave on top of the existing slave? Please share your experiences? I have seen one big black hexagonal nut on the right side of the cells, I am hoping not to touch those.
Many thanks,
Prasanna
Many thanks,
Prasanna
I did upgrade over the weekend and have created a manual to follow, find it here
viewtopic.php?t=54
Hope this is helpful
Thanks,
Prasanna
viewtopic.php?t=54
Thanks,
Prasanna
I've had a Fox H1-3.7 Inverter and 12.09kWh Cube battery for a few months now and am delighted with how it is performing. I decided to add a little more battery capacity as there isn't quite enough with 12kWh to load shift all our usage onto cheap overnight rates.
So I ordered the ECS4100 slave battery to simply add to the stack it has arrived this morning with a very bold V2 sticker warning that it can only be used with a V2 BMS.
I'm aware that this is a well publicised 'thing' with the HV2600 batteries but nothing is mentioned about the Cube having a V2...
Has anyone come across this?
Hi.
I'm planning to add CS4100 batteries to my system but ran in to same issue with V2 not being complatible with V1. It appears I have to throw away the brand new CM4100 V1, never used, and buy a new V2. Is this real? What about all the fancy marketing these batteries can be upgraded any time in the future. Anyone found a solution to this. Any feedback from FoxESS, as they don't care to reply to any of my emails regarding this subject?
I had the same problem, in October last year I bought additional slave cube CS4100 and turns out it was V2 slave. Fox replaced my old master CM4100 V1 for new one CM4100 V2.
I found Ollie Morris at The Eco Supermarket for my additional slaves and I thoroughly recommend him.EcoJones wrote: ↑Sat Nov 05, 2022 1:28 pmI still can't locate any 4kW cube slaves in stock, you are ahead of me and I haven't got any more information to give.Prasanna wrote: ↑Tue Nov 01, 2022 3:27 pm Hi
Many thanks,
Prasanna
However if you can, could you please share your experience of the upgrade. Your questions are good ones and I would like to know the answers to them as well, I'm sure others would too.
Thanks.
024 7698 1489
info@theecosupermarket.co.uk
www.theecosupermarket.co.uk
ups-solar are always happy to assist 3rd parties in additional batteries and looking at the comments believe we would
be very competitive with install included. Be careful as its firmware on the different batteries that needs to match as well.
