FIXED: Cannot disable Manual Mode Scheduler
Posted: Tue Dec 16, 2025 6:59 am
by mikeincairns
How do I disable the Manual Mode Scheduler??
Note "Enable" in this app
actually means "Enable
d" and "Disable" actually means "Disable
d"
Manual Mode Scheduler started off indicating "Disable".
Was experimenting with Manual Mode Scheduler and put in some time frames. Now have deleted the schedules, but Manual Mode Scheduler still indicates "Enable".
Re: Cannot disable Manual Mode Scheduler
Posted: Tue Dec 16, 2025 7:11 am
by mikeincairns
I may have answered my own question here but others experience would be appreciated. Looks like a software bug.
This was a PITA to fix. Essentially you
cannot fix it on the mobile app.
Here is how I fixed it.
1. Had to do it using the
online web app > Go to Quick Settings > Mode Scheduler
2. Remove all schedules then create a new blank one from 00:00-23:59
3. Disable this schedule
4. Submit
5. Mode Scheduler is "Disabled"
6. Now I can use Grid Charge Settings again without error.
Here's what Chat GPT found:
1. The Scheduler Has to Be Actually Removed, Not Just Turned Off
In the Fox Cloud app (especially v2), simply switching Mode Scheduler to “Off” often doesn’t actually remove the schedule from the inverter.
The app may show “Disable,” but the schedule is still stored in the inverter and still controlling settings.
Because of this, other settings (Work Mode, Charge Times, etc.) are blocked while a schedule exists, even if it looks disabled.
Known App/Cloud Bugs
Many users report Mode Scheduler settings either not sticking or re‑enabling automatically:
The Cloud 2.0 app and web portal are still buggy: schedules sometimes don’t show, or you get errors like
“Failed to get device timer mode settings” even after you think you’ve deleted it.
Overclockers UK Forums
Simply deleting schedules in the UI often doesn’t actually submit the change to the inverter, or the app fails to push the change.
There are reports where firmware interactions make scheduler settings stick even when shown as disabled or deleted.
Re: FIXED: Cannot disable Manual Mode Scheduler
Posted: Tue Dec 16, 2025 11:13 am
by MaterialBarracuda48
Here is a shorter method to disable the Manual Mode Scheduler.
Posted: Tue Dec 16, 2025 12:17 pm
by mikeincairns
Materialbaracuda48. Thanks for your input. That setting might only apply to UK. I am in Aus and don't have that setting.
Here is what I see. Even when you toggle off and Submit, the Mode Schedule stays on.
Posted: Tue Dec 16, 2025 12:25 pm
What does your page before this show?
Posted: Tue Dec 16, 2025 12:54 pm
by mikeincairns
Posted: Tue Dec 16, 2025 12:59 pm
I guess we have an extra screen as we have Octopus Agile as an extra choice in the UK.
So your work around, does the trick for Aus users, so a good find and write up for others to find.
Posted: Fri Dec 19, 2025 8:25 pm
by Rhi
I’m having the same issue.
When you create a new blank one from 00:00-23:59, what are the setting? Self mode?
Posted: Sat Dec 20, 2025 2:13 am
by RaikonPT
I've solved this exact problem right now. I've been scrambling for a while...
. Go to
https://www.foxesscloud.com. V1 SITE. NOT THE NEW ONE
. Select devices
. Select inverter
. Select your inverter and go to the details page.
. Middle of the page you will see your home setup
.Work Model - click the edit button
. New page will appear.
. In the user-defined tap you have one option.
. STRATEGIC PERIOD = DISABLE that button.
It's done
You now should change minSoc and battery reserve without errors
Hopefully this will help
Posted: Sun Dec 21, 2025 9:35 pm
by ShaneOZ
Legend thank you for sharing!
Posted: Sun Dec 21, 2025 11:46 pm
by SoFather
I've been charging my car, and it kept using my Fox battery & the grid to charge.
I was manually setting min battery reserve to 99% and min soc to 99% and this solved it.
Then I looked at setting up a schedule so I could simply use the schedule to do the same, so I didn't have to remember to manually set it.
But before I set the schedule, I didn't put battery reserve and min soc back to 20%
That's when it messed up, and now my battery is stuck on 99% and I can not alter it.
I’ve tried everything mentioned here and more.
I tried to set min soc on the inverter screen itself. But it won’t let me there either.
My issue seems to be a known one.
As I found this
The "099%" display is a classic symptom of the Manager 1.61 firmware bug or a mismatch
between the Master and Manager versions. • Check Versions: On the inverter screen, go to About and find your Master and Manager
(ARM) versions. • Contact Support: If you are on Manager 1.61 or earlier, email
service@fox-ess.com with your serial number. Ask them to "remotely push the latest firmware update to clear the 99% SoC lock". Installers have special "Agent" accounts that can push these updates in
minutes, while end-user accounts cannot.
Have raised a ticket with Fox. Hope they get back to me Monday.
Posted: Mon Dec 22, 2025 1:42 am
by WyndStryke
I can't disable the mode scheduler via the app either, but using the Fox Cloud 2.0 website, if I first enable then disable the final remaining slot in the mode scheduler on the website, then submit, then the mode scheduler then shows as disabled in the fox cloud 2.0 app.
Posted: Mon Dec 22, 2025 1:56 am
by ShaneOZ
Thanks for sharing this! Ps, would you be able to force charge from the grid when charge from grid is enabled? Mine only charges the battery from solar not from the grid for some reason, wondering if anyone else experiencing similar issue, in Australia.
Posted: Mon Dec 22, 2025 2:44 am
by 69YAO
recently installed the system and i am having the same issue.
can't turn the mode scheduler off, anyone has any luck?
Posted: Mon Dec 22, 2025 8:46 am
The Fox app is not turning off the scheduler master switch, if you have installer access to the system you can disable it by setting this setting ‘SegmentedTimedModeEnable’ off.
The Energy Stats app by Al Priest (available on iOS and Android) does disable the scheduler when you turn it off - that seems a good way to resolve this issue.
Posted: Mon Dec 22, 2025 8:49 am
SoFather wrote: ↑Sun Dec 21, 2025 11:46 pm
When you set a schedule the minSoC setting endures after that schedule has ended - if the scheduler is enabled you will not be able to set it via the app or the inverter screen, try adding another item in your schedule that sets the workmode to say Self Use and minSoC to 10% for the rest of the day and that should get you going.
Posted: Mon Dec 22, 2025 9:09 am
by SoFather
Thanks for the reply.
Yup I’ve tried that one.
And bizarrely if I do when I return to it it’s changed from 10% to 99% on its own. Even thought it said it was saved. And i did submit after.
So there’s a deeper issue going on I’m afraid.
Posted: Wed Apr 01, 2026 8:31 am
by jonathanb48
have been having this exact problem with the scheduler and thought I had solved it but it seemed that the scheduler reactivated itself last night and interfered with the charge start triggered by my home assistant automation. have had to redisable or switch off enable everywhere and then go back to manual selection of self use whcih should the allow Home assistant to control ( im making this up as i have no idea what Im doing!
Posted: Wed Apr 01, 2026 9:51 am
jonathanb48 wrote: ↑Wed Apr 01, 2026 8:31 am
I have posted this before, but me and my son would both use the App to look at the system, he was on the iPhone version and I had the Android version. We started to get some weird things happening, the system would randomly charge the battery at peak prices, or the times/values of the schedules would alter. Once I got him to stop using his copy for a while, it stopped altering.
Not saying you are using several methods to access, but recommend if possible to just adjust / look on the website for a while only. If the errors go away, then the App would most likely be the culprit, "pushing" values back to the cloud and adjusting settings.
Posted: Wed Apr 01, 2026 9:53 am
by jonathanb48
That’s a great call - I am terrible for checking so will simply make sure home Assistant cloud is set up as well as network version
Posted: Wed Apr 01, 2026 10:03 am
jonathanb48 wrote: ↑Wed Apr 01, 2026 9:53 am
It's very hard not to check with the phone in your hand!
But maybe try just the website method for a few days, and if stable, try the App again.
If the system goes stupid, then you know the App is pushing values out to cloud/inverter.
Best of luck to you.
