EV car charger control from HA Modbus
Posted: Sat Dec 13, 2025 6:30 pm
by Elboz
I have inverter H1-5.0, battery EP5 and EV charger APEX-7S .
I have a Citroen car which does not natively manage the % of charge limitation.....
On HA
- I have a foxess ModBus add on
- the Citroen add-on ( but as it is unofficial, I do not know how long it will work).
So I would like to create an automation to start and stop the car throw EV charger ( like it is possible to do in the application ) depending on the car state ( connected and % of charge).
But I do not find EV charge capability on the modbus add-on (only fox battery management).
Is there a way to manage the car charger from the ADD ON or adding this capability ( as it can be done throw the Foxess app, I guess the back functionality exists.
I am not a developer expert, but still a developer and I can help if needed on the HA add on development
Re: EV car charger control from HA Modbus
Posted: Sat Dec 13, 2025 7:02 pm
by Will
Looks like someone has made an integration so you can control the car
https://community.home-assistant.io/t/s ... ant/838675
Posted: Sun Dec 14, 2025 3:46 pm
by Elboz
Thanks for you answer.
Yes this is the one I use. But as it is a non offical one, I am afraid to loose the car control at any time. Meaning I do not want to setup the charge to 80% and prefer to use an official add-on like the fox one. My idea is to use the stellantis as sensor and manage the start and stop car charge throw the fox add on which is offical
Thanks again
Have a nice day.
Posted: Sun Feb 15, 2026 3:37 pm
by Elboz
As it looks not possible to query throw HA mobulus,
I buid an android app (that I will transform to HA add on later) to autorise the charge only during some timeslots and setup a schedue and so stop the charge at 80% (by estimating the end of charge )
to do so I need to know when the cable is plug to the station.
my charger model is A7300S1-E-2-WO.
I do not find the api end point or query to check the cable status ( I have the information on the app itself so I think fox cloud has the information throw the api.
Thanks for any support
Posted: Thu Apr 30, 2026 4:46 pm
by ricardofaria
Have you checked this repo: https://github.com/ringaction/foxess_charger ?
It is a HA custom integration that connects you charger with modbus. Its a great advancement on this. Already tested on HA but finding a minor issues.
Posted: Sat Jul 04, 2026 3:53 pm
by Elboz
Thanks for you support.
This looks good for my initial purpose, it looks to work.
As I also try to build my android app do you know how I can get thoses informations throw the api. I do not fnd the charger (I found everything else, but not the cahrger
